tranny removal..help
Old Sep 23, 2002 | 08:47 PM
1987chery z's Avatar
i have a t 5 borgwarner on my 87 berlinetta and im trying to get that damn tranny out. all the bolts are out but it just wont yank out that stupid bell housing....the tranny is supported by a jack for now, im stuck...its my first time doing a tranny job and have no idea of what to do next...please help....suggestions are greatly appreciated.
Old Sep 23, 2002 | 08:56 PM
4L60bliss's Avatar
If your sure that all the bolts are out, then its probably hung up on the dowel pins. There are two pins, one on each side.
Old Sep 23, 2002 | 09:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's no dowel pins on a T-5...
There are 4 bolts that hold it to the bell housing. Make sure you took out 4.
That's all that holds it in. Once they're removed, the trans should practically fall out.
Old Sep 23, 2002 | 09:16 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
make sure your car is on jackstands
now lay underneath the T5
(its only about 80 pounds)
and "bench press" it out
thats the easiest way to do it
thats how i did it in my own driveway
Old Sep 24, 2002 | 05:44 AM
4L60bliss's Avatar
I was assuming he was removing the tranny/bellhousing from the block.
Old Sep 24, 2002 | 07:42 AM
Recluse's Avatar
make sure you are pulling straight out -not slightly downward. It will bind up and never come out . Sometimes it takes a good strong jerk to pull it out...heh heh. You know what I mean.
Old Sep 24, 2002 | 10:06 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
I just pulled mine and the only hard part was getting the 4 bolts loose.. i put an old matress under the car and like they said just had to support the weight of the trans by pushing up on it from underneath and then pushing back to let it out. then layed it on the mattres slid it out and started on the bellhousing. which was also a pain to get the bolts loose. the real trick is getting the trans back in. you have to make sure you guide it in straight, so if you only have the front end jacked up as I did it makes it a little harder to judge the angle. good luck..
Old Sep 24, 2002 | 03:58 PM
thanks for the suggestions....ill try them out and keep you guys updated with the progress.
Old Sep 24, 2002 | 11:23 PM
ya guys that damn tranny wont just come out...i think that thing is binded up. what does it mean when its binded up....and what can i do to get that thing out.....this is very frustrating...please help...thanks much.
Old Sep 25, 2002 | 12:08 AM
Redliner's Avatar
Car: Tahoe
Two people
one ball peen hammer
two jack stands ( one on bell housing and one on trans)
One thin head screw driver ( put between bell and trans)
Three anger management classes
Old Sep 25, 2002 | 09:19 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Is it pulling away from the clutch housing at all?
Old Sep 25, 2002 | 09:30 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
This might sound stupid, but have you unbolted the shifter yet?
It ain't gonna move much with it in.Other than that it should come out pretty easily. The only time I had trouble (I've done my clutch 11 times) was when the throwout bearing was seized onto the input shaft bearing retainer.That time it required a little "beating on" to get it out.
-Rich-
Old Sep 25, 2002 | 09:48 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Good point. Make sure everything is unbolted.. this includes shifter, driveshaft, torque arm. cluch cable, connecter to catalytic converter, trans crossmember, and I think thats it. let me know what exactly its doing and I'll try to help more.
Old Sep 25, 2002 | 01:51 PM
83 MidniteZ's Avatar
...prybar
Old Sep 25, 2002 | 01:58 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
-Rich-
11 times? Dang, what do you do to those poor clutches?
Old Sep 25, 2002 | 03:08 PM
Car: 92 Camaro RS
My RS has 227,000 miles on it. Mostly driven pretty hard (and daily).
-Rich-
Old Sep 26, 2002 | 10:47 PM
laiky's Avatar
the tranny might be corroded in the bell housing.
or you might have it jacked up too high and the shifter mountiing housing is getting stuck in the cutout inthe tranny tunnel.
when removing the tranny just let it hang off the motor. you might be binding it by jacking it up.
Old Sep 27, 2002 | 11:18 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Have you gotten it out without any troubles? let us know. getting it back in is a little harder than out. Just make sure you line the trans up straight with the engine.. good luck.
Old Oct 26, 2002 | 11:12 PM
well i got that tranny out and put in the new clutch assembly. but i cant get it in gear?? what do you guys think.. would it be my hydraulic clutch system??...i dont know..........it might not be pushing my fork in enough to dis engage that new clutch.....pleas help ....ideas are greatly appreciated...thanks.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
