4th gen rearend in a 3rd gen, is it possible?
Old Sep 24, 2002 | 10:48 PM
SX Stinger's Avatar
Car: 84 Z28 "Holly" (SOLD)
Engine: Carbed 305
Transmission: TH350
What size rearend do the 4th gen SS Camaros and WS-6 Trans-Ams come with? Will it fit in a thirdgen and if it needs mods, how much work,? I am just do the research before I do my engine swap.
Drew
Old Sep 24, 2002 | 11:27 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
yes its possible, it will stick out about 2 inches though, there is a tech article on how to do it
Old Sep 25, 2002 | 01:18 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yes, I , as well as quite a few other people have 4th gen rear axle assemblies in their 3rd gens. The wheels will stick out 1.5 inches farther with a 4th gen rear versus the 3rd gen rear if you keep 3rd gen offset wheels. 4th gen offset wheels would be the correct backspacing to get you back to where it should be if you go to a 4th gen rear axle in a 3rd gen. There have been numerous threads about this swap (hint: do a search for more info) and there is a tech article on it, as mentioned above.
Old Sep 25, 2002 | 05:38 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i have a 4th gen rear in my Z28, it was simple, everything bolts up as normal
Old Sep 25, 2002 | 05:48 AM
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
Thanks guys I appreciate the help. What is the biggest size rearend they put in the 4th gens? Im trying to find an alternative to spending $2000 on a 9" rearend.
Drew
Old Sep 25, 2002 | 06:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're all the same "size", which is also the same "size" as the ones in 3rd gens except as noted above... what is it you really want to know about them?
Old Sep 25, 2002 | 07:54 AM
Ringmaster72's Avatar
Car: 1989 IROC
Drew, I have a 3.23 ratio 4th gen rear, if you are interested. It has the discs and calipers also. It is out of a 96 Firebird I believe.
Tim
Old Sep 26, 2002 | 01:14 PM
SX Stinger's Avatar
Engine: Carbed 305
Transmission: TH350
Tim how much are you asking for the rearend out of the firebird?
Old Sep 26, 2002 | 02:25 PM
Car: 1989 IROC
$175 plus shipping.
Tim
Old Oct 6, 2002 | 06:39 PM
TealRS2000's Avatar
Hey, did you sell it yet????????????
Old Oct 7, 2002 | 08:01 AM
Car: 1989 IROC
Yeah, I am pretty sure that it is sold, but if the deal falls through, I will let you know.
Tim
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
