700r4 Modifications
Old Oct 3, 2002 | 11:47 AM
headhawg7's Avatar
700r4 Modifications
I have a 700r4 that is really good shape. I just put in a 383 stroker and it shifts fine when I am not trying to hot rod it. When I do hot rod it , it shifts fine no hard shifts it just doesnt shift when it needs to. I am thinking about putting in a B&M shift kit so that I could shift when I want it to or drop it down a gear to take off real quick. That is the closest thing I can think of doing w/o putting in a 5-speed. What is yall's thoughts on this. I am not wanting to spend tons of money otherwise I would just put in a 5-speed. Any help would be appreciated. Thanks Danny
Old Oct 3, 2002 | 12:10 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
you can get a govoner recalibration kit from summit or jegs. lemmie see if i can find the part number....
Old Oct 3, 2002 | 12:12 PM
curt86iroc's Avatar
Car: 1990 IROC
http://store.summitracing.com/partdetail.asp?part=10100
heres one...
Old Oct 3, 2002 | 01:30 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The B&M kit will not give you the results your looking for. Either go with the governer calibration kit mentioned above and remove the MTV upshift spring "second small valve on the passenger side front " or get a TG shift kit.
Old Oct 3, 2002 | 01:36 PM
headhawg7's Avatar
will i get the results I want
Will I get the results I want going with strictly the conversion kit? I do have the money to go with the TransGO, is that what you guys would do?
Old Oct 3, 2002 | 10:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Probuilt sells the kits cheap I assume you just want the Jr shift kit. The B&M Shift Improver kit only makes the car shift harder by boosting the line pressure and limiting accumulator travel. None of these shift kits will change your normal shift points, thats done through the governer calibration kit. Removing the MTV upshift spring will delete the forced 1-2 shift and it can be done when changing the fluid for free.
Old Oct 4, 2002 | 04:08 AM
Pro Built Automatics's Avatar
You could install one of my Trans-Go Performance Shift kits (with accumulation) along with the Corvette servo, and both large boost valves. Depending on what year you are trying to install this into?, and what WOT shift rpm are you trying to obtain? you might need to change governor along with the shift timing springs. Let me know?
Old Feb 3, 2003 | 12:26 AM
ben73's Avatar
Does anyone have a pic of the valve body which clearly identifies the MTV? I don't want to remove the wrong one! ;-)
Thanks,
Ben.
Old Feb 6, 2003 | 03:54 PM
ben73's Avatar
Ok, here is a pic of the valve body. Which spring do we need to remove to disable the forced 1-2 shift?
Old Feb 6, 2003 | 03:58 PM
ben73's Avatar
I'll try again ;-)
Here is a pic of the valve body. Which spring do we need to remove to disable the forced 1-2 shift?
Old Feb 6, 2003 | 04:28 PM
EricZ103's Avatar
hey guys I got a coulple of questions about the governer recalibration kit. All it does is adjust your shift points correct? Can you set the point where you want it too shift. How hard is it to install? I just bought my car, and shifts at about 1500 rpms to high, so I correct with this kit? As you cant tell I don't know alot about transmissions. any help?
Old Feb 6, 2003 | 07:35 PM
87transam5.7tpi's Avatar
ttt, does anybody know what the MTV is on the valve body? I"m wondering this too. thanks
Josh
Old Feb 11, 2003 | 12:52 AM
ben73's Avatar
Is someone able to confirm which is the MTV on the pictured valve body?
Old Feb 11, 2003 | 03:34 AM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Josh
what does ttt stand for ? I have asked before but got no reply. Stupid question, but I cant figure it out
thanks
Old Feb 11, 2003 | 01:35 PM
ben73's Avatar
it means 'to the top' so the post goes back to the top of the list where someone who can answer the query might see it!
Old Feb 16, 2003 | 05:54 PM
ben73's Avatar
Whoops, looks like i posted the wrong pic..
I think the spring we must remove in this pic is '304 - spring, tv modulator upshift valve'. Anybody with knowledge in this area who can confirm this?
Old Feb 17, 2003 | 03:50 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
SSC Where are you????
Old Apr 4, 2003 | 10:56 PM
ben73's Avatar
Ok, I have removed the spring labelled 304 (MTV)in the above drawing and I still have a forced 1-2 shift. In fact, as far as I can tell, the trans doesn't behave any differently!!! Can one of the trans experts here tell me where I have gone wrong??
Thanks,
Ben.
Old Apr 4, 2003 | 11:58 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Eric, the shift points are determined by both the Governor and the TV cable. It may be just the TV cable needing adjustment, especially if the trans shifts right after you let off the gas. I would tend to think that you just need your cable adjusted. I posted a quote a little while ago. Here's a link to it: https://www.thirdgen.org/techbb2/sho...hreadid=171302
I would reccomend trying this first, it is much simpler, and it is free of cost to do it!
Good luck!
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
