Can a 1985 700R4 handle 400ft/lbs at the flywheel.
Hey
I am planning on getting a 383 stroker built this winter and the engine is built to put out 400ft/lbs at the flywheel. I am wondering if the stock bottom end is going to be able to handle that power or am I gonna blow it to nothing.
Thanks alot.
Thanks alot.
I have heard that the 1985 700R4s wernt as strong as the 1987 and up 700R4s, I forget what its called of the top of my head but somthing in the 1985 700R4 twists.
How long do u think the transmission would last with the 383. Ill be braking the motor in so I dont think I will be bagin on it.
I think it is the input shaft, Ibeleive the earlier trans. have 27 splines and the later ones have 30 splines.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
