down shift 700r4 problem
Old Oct 16, 2002 | 04:50 PM
Raiden's Avatar
I recently purchased a stage 3 700r4 for my 92Z. The old tranny used to shift into second on the freeway just below 59mph. Now, the new tranny will not down shift into 2nd unless i'm under 50mph? When i used to stomp on it on the freeway, it would be at the top of the rpm's but it would give me the needed power. Now, the new tranny does not down shift unless i'm going a lot slower. It does not give me the power i need unless i shift manually. I adjusted the Detent cable as specified and also used transflexio's method. No change? Any Ideas ???
Old Oct 16, 2002 | 06:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like the governor of the new transmission doesn't match your rear end gears. You can get a kit to tune the governor, or if you still have it you could try swapping the old governor into the new transmission.
Old Oct 16, 2002 | 06:14 PM
Raiden's Avatar
I have never changed the govener? Where is it located and how hard is it to change??
Old Oct 17, 2002 | 01:07 AM
Raiden's Avatar
Anybody? pictures???
please!
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
