Trans banging noise
Old Oct 17, 2002 | 12:19 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Trans banging noise
i have a 700r4 trans in a 92 firebird, when i jump on it at a lite or stop sign sometimes i get a loud bang/clank noise when i accelerate, are there rubber bushings on the trans crossmember that have gone bad or have i broken a bolt loose holding the transmission, the universal joints are new in it so i know thats not the problem with it......any suggestions on repair or how much a shop would charge to fix it.....thanks guys
Old Oct 17, 2002 | 05:27 PM
4L60bliss's Avatar
It sounds like a transmission mount. I would hope that you wouldn't take it to a shop to replace. Its a very easy to replace. Its about as basic as changing your oil.
Old Oct 17, 2002 | 05:29 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
sounds to me that you have a bad tranny mount....... if you can get a polyurethane one cause the stock ones dont last long and take it easy on it till you install the new one !
Old Oct 17, 2002 | 05:40 PM
Car: 1996 Camaro
Engine: 3800 V-6
Thanks alot guys for your input, i have seen all the input about the ES trans mount bushings, would the ones that Spohn's make for it a $22.50 be a better deal ???, also how many are there to replace ????
Old Oct 18, 2002 | 05:36 AM
Car: '88 GTA
Engine: L-98
only one, it is right behind your tranny pan between your tranny and the crossmember it has 2 bolts (that go into the tranny) and one nut on the crossmember! as for prices....... i dont remember what mine was but i do know that is an energy suspension one.
good luck
Old Oct 18, 2002 | 11:23 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
while you're under there look at the torque arm mount too. just follow the torque arm to where it slides in to the forward mount, if the rubber there is shot it'll move up and down in the mount and go "bang"
Old Oct 18, 2002 | 03:15 PM
Car: 1996 Camaro
Engine: 3800 V-6
Thanks alot guys for all of your input on this, if the control arm mount is bad also can u get poly ones for it also and if so who would u recomend .....thanks
Old Oct 18, 2002 | 04:37 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
yes you can get a poly torque arm mount, I think ES makes those too. You have to do a little modification to the OEM mount to install it, basically grind or drill a few rivets out...not a big deal.
Old Oct 19, 2002 | 06:31 PM
MdFormula350's Avatar
this is a good tranny mount also
http://www.slponline.com/view_produc...RTNUMBER=60005
Old Oct 22, 2002 | 03:15 PM
Car: 1996 Camaro
Engine: 3800 V-6
Hey.......just wanted to let you guys know that all of your information is the greatest!!!!!!!!....just put in my ES Trans mount and Torque arm mount ( a dremel is the best thing ever made ) and let me tell you what a difference than stock.....you guys rock!!!!!......the car rides so smooth and shifts much firmer and the nose doesnt jump up as high as before.....the stock ones were Wasted and all tore up....lol... next investment ( Transgo shift kit and vette servo ).........once again thanks alot for all of your input and help.....
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
