shift linkage problem (700-r4)
Old Oct 19, 2002 | 10:35 AM
theCure's Avatar
Car: Looking
alright i've got a 91 z28 (auto) and recently i had to put in a new shifter cable, both cables looked identical and same length, but everytime i adjust the linkage, and then get in the car to "test" it. i move through the gears and when i get into park, the tranny is in reverse, and i have done adjusted it to many times to count and i dont know why it does it. i can put in in park under the car, and get in the car and hook it all up wheres its in park in the car too, but when i try it, it does the same thing, after i take it out of park it wont go back in. any suggestions? is it possible that its to short, even though they both seem the same length (the old and the new)? any help would be appreciated, thanks
Old Oct 19, 2002 | 02:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The overall length of the cable isn't going to change anything, it's how far the cable moves inside the sleeve that matters. All I can think is you're doing something wrong. Is the nut moving inside the slot when you tighten it?
Old Oct 20, 2002 | 10:34 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I have the same problem also. I have adjusted it plenty of times, and tried to fix stuff, but it just won't work. If I throw the lever into the park position hard enough, it goes into park, but other than that, I just use my Ebrake now. When it is in different gears, the shifter is loose too. It doesn't lock itself from gear to gear so I can wobble the shifter forwards and backwords while driving.
Old Oct 21, 2002 | 02:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
How are you trying to "adjust" the cable? Are you loosening the nut, puting the shifter and the manual shaft in neutral and then tightening the nut?
Old Oct 21, 2002 | 05:20 PM
Sonar_un's Avatar
Car: '86 T/A
I did that, but no matter where it goes, it doesn't help, in fact, at its "tightest" setting, it doesn't even reach. Its been a real pain in the ***.
Old Jul 27, 2003 | 02:29 PM
plain82's Avatar
Sorry to bring up a dead thread, but I have a possible solution to the shift problems mentioned. Check where the cable attaches to the shifter and make sure the little plastic tabs are not broken.
Old Oct 6, 2003 | 05:40 PM
ZOHNNY's Avatar
Yeah I Got Cha!
I am having the same problem with mine, did you figure out why your linkage wont work in park?
John Whittum
Old Dec 7, 2003 | 02:57 PM
justgot86's Avatar
Car: 86 Camaro Z28
Engine: 383
Just for info
I know its old thread but thought I should put in my 2 cents anyway.
I bet your problem is the sleeve is broken. If you pull back the boot you will see a plastic sleeve, check to see if that has broken.
Just a thought.
Rob
Old Mar 27, 2004 | 05:57 PM
1984Camaro350's Avatar
Also make sure that the shifter is in neutral and the trans is in neutral when you do the adjustment.
Yes it makes a difference.
Old Aug 31, 2004 | 01:32 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
i have this same problem now! when you mention the "sleeve is broken" what do you mean by that?
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
spaigo
Aug 21, 2015 07:46 PM
dhonda200
Aug 11, 2015 11:50 PM
