no reverse after shift kit install
Old Aug 29, 2004 | 06:22 AM
ausrs's Avatar
subject heading says it all ..after spending hours dropping everything reading the instructions carefully ,fit the thing back together (covered in atf) start the car ,,.........everything looks good till i put it in reverse ..anyone had similar problem ?? if so what did you do to fix it ???
BTW its a B&M transpak
Old Aug 29, 2004 | 07:04 AM
screamin' 85 z's Avatar
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
I had the same problem with one I did about 5 years ago!... The pressure regulator where you put the spring in, then the piston, and have to hold it there while you put the C-clip in had fallen out... I'm pretty sure you know which piece I'm talking about, 'cause it's a pain in the *** to get in. Problem was, the C-clip that came with the kit was too thick, and didn't seat in the groove right!. I reused the old one, and got reverse back!! I hope this helps you out... Sucks to waste all that fluid! I had trick shift in mine
Old Aug 29, 2004 | 10:49 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes that will do it. While you have the clip out double check your PRV valve assembly to make sure its correctly assembled most of the time it will fall out anyway if the clip comes loose.
Shift kit time is always a good time to install a $6 drain plug.
Old Aug 29, 2004 | 11:36 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
That's exactly the same issue I'm having. I double checked the clip when I put it in, and have never had that problem on the 15 or so other times I've done this! Of course I would have to develop problems on my own car! All forward gears work fine (not driving, just on the lift) but I can't back it out! LOL
I should have put in the drain plug, I even bought one! I think I will now that IO have to drop the pan again! I gues I was just trying to keep from jinxing myself!
Old Aug 29, 2004 | 04:58 PM
JP84Z430HP's Avatar
Car: 84 Z28
I'm almost too embarassed to say what was wrong with mine!
I left out the reverse boost sleeve and valve. In my defense, the transmission has been sitting apart for about 6 months, and the last 700 I had apart was about 4 or 5 months ago. I had gotten to the point where I was in a hurry to finish the build, and overlooked that one little thing! The TV boost sleeve (aftermarket with o-rings) was a PITA to get back out without the spring pressure pushing it out! I finally found a magnet strong enough to do the job, but I still had to work it in and out to get it out!
I guess this just backs up the need for attention to detail, and double checking EVERYTHING!
My next problem is with the TCC wiring being different, and 1-2 shift seems to happen too quick. All else seems fine!
Old Aug 31, 2004 | 02:55 AM
ausrs's Avatar
yep that was the problem the B&M clip is noticably thicker than the GM clip
re installed using GM clip and all is well .......what a pita job to do
Old Aug 31, 2004 | 05:24 PM
Car: 85 IROC
Engine: 355 CI n/a
Glad it fixed it, man!! I know you're relieved!!
Old Aug 31, 2004 | 08:55 PM
JP84Z430HP's Avatar
Car: 84 Z28
Yeah, I have all gears now, and I'm driving it. At WOT, everything is good, other than the shift points are early (governor). At part throttle (1/3 and less) the 1-2 and 3-4 are real early, and the 2-3 late. Gonna get the governor right, then mess with the springs on the shift valves (I used the reprogramming kit, and the "syskokal" (green and black box) kit (Transgo). I may make another post if I don't find anything with !
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
