700R4 Doesn't shift/downshift right
Old Oct 28, 2002 | 09:49 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
My car doesn't shift right while i'm driving. It's a 700R4 in my 85 iroc-z and it's done it ever since i've had the car. One thing is if i'm accelerating around 1/2 throttle or less, my car will very quickly shift into O/D. It'll shift into O/D at 30 in town if i let it and then it won't downshift at all until i give it about 3/4 throttle and it'll downshift into 2nd. It does this at any speed. Another thing is that when it's in 3rd gear and i'm going almost a steady speed, the rpm's will slowly go down 200-250 almost like it's shifting into O/D. I know it does this in 3rd b/c it does it if i have it in drive as well as O/D. (sometimes it does this when i'm accelerating) I recently upgraded to a 730 SD ECM and when i first did the swap, it worked PERFECTLY in every aspect for about 3 or 4 days and now it's doing pretty much what it did with the original computer in. The weird thing was that if i swapped in the old computer it would shift like **** and i could plug the new computer back in and it would drive like a champ....?? I don't know what the hell is going on but i'd really like to get this fixed b/c i REALLY liked the way it worked when it was working right. Any ideas would be greatly appreciated.
Old Oct 31, 2002 | 09:22 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
anybody at all have any ideas????????? i'm gonna adjust my tv cable and change the tranny fluid and filter and see if that fixes it. other than that i don't know.....
Old Oct 31, 2002 | 10:34 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The ECM does nothing for shifts in an early transmission.
It sounds like the tc is locking in it's normal operation range 35MPH+ at a steady speed droping the RPM's like it's supposed to. I suggest doing what you plan on. Adjust the TV cable, change the fluid and then see what happens. These 700r4's are very picky with thier TV cables and a misadjusted cable "loose" can cause all kinds of shift qulity issues.
Old Nov 1, 2002 | 08:19 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
yeah, i know the ecm doesn't control the shifts in the tranny, just the tc lockup. that's what makes it so weird. i couldn't figure out what was making it work right for those first couple days. it's weird. but, right now my car's COMPLETELY stripped down b/c i'm painting it. but i'll be finished this weekend hopefully so i'll adjust the tv cable and try it out.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Vojtush31
Oct 11, 2015 01:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
