how to identify bad synchros
Old Nov 11, 2002 | 07:10 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
as we all know by now, i pulled apart my T5 a while ago,
it had symptoms pointing to bad synchros
i looked at the synchro sleeves and i see nothing wrong
what should i be looking for?
Old Nov 11, 2002 | 09:33 PM
TexasLT1's Avatar
Car: '92 RS
well, when I pulled apart my T-5, I knew my 1-2 synchro was definitely bad. sure enough, when I got the synchs out, if you look at the synchro and th"teeth" on it, the 1-2 was rounded off on every tooth pretty badly, almost flat spotted. the synchros I replaced them with had nice points on them, and I didnt have any grinding when I got it back in the car. so I think that is what goes bad. I may be wrong though.
Old Nov 11, 2002 | 10:58 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
when you look at the synchro (the brass ring) you should have sharp teeth, and on the inside bore you should have little grooves on them where they ride on the gear. if these grooves are worn you will have bad shift quality.
Old Nov 12, 2002 | 06:02 AM
Pro Built Automatics's Avatar
The groove (one long groove) on the inside of the syncro ring must be on the sharp side (the top of the groove), use a magnifying glass if need be to see this. Put the new syncro ring on the gear you are having problems with and check the clearance between the syncro & gear with a feeler gauge, it should be .050 or more, if not try another syncro ring. The engagement teeth on the gear should be sharp to slightly round., same thing for the sliders. Use the recommend fluid called for for the unit, but only the highest quality. Make sure there are magnets in the trans, wherever an extra one can be added, do so. If the unit has been run low on fluid, then there is a chance of a gear or gears being burned, if this happens........well it can be expensive.
Old Nov 12, 2002 | 07:18 PM
yeah, i'm just trying to decide whether its cost effective to rebuild it or not
i dont really need the trans, but a rebuild kit is about $150 and new synchros are about $200, so thats kinda alot
i would like to have the trans as a spare though incase i blow my current T5 before i put the 350 and hopefully a T56 in
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
abrilnelson89
Sep 16, 2015 02:19 PM
gta892000
Sep 16, 2015 12:40 AM
angel2794
Sep 8, 2015 06:22 PM
