Diff Problem
Old Nov 11, 2002 | 08:14 PM
xformula79's Avatar
Diff Problem
I got the 10 bolt posi rear end out of my car and on jack stands about to rebuild it. I started dissassembling but when I took out the pinion shaft lock bolt I noticed that it was snapped off and the majority of the bolt is still running through the pinion shaft making it impossible to take apart any further... I think. I tried to drill it out but there is not enough clearance to get the drill in straight (because of the housing) and also the bolt is a very strong grade making is difficult to touch with a drill bit. I am willing to break things that can be replaced in order to take it apart. Any suggestions on the easiest way to get this rear end apart???
Old Nov 11, 2002 | 08:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's very common on GM diffs. There might be half a thread still holding it in. There shouldn't be any torque on the remaining bolt since the clamping force is all done on the head of the bolt. Use a dental pick to try and back it out. I've had very few that wouldn't come out.
Old Nov 13, 2002 | 05:36 PM
xformula79's Avatar
Being that there is a lack of room to work with, it seemed to be impossible to use an easy-out and I wasn't able to grab it with anything to pull it out. I ended up using a grinder and gring a slot right over the top of the pin to get access to it and push it out (obviously ruining the posi unit... no big deal it was old & abused).
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rudolphschenker
Sep 4, 2015 02:41 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
