1400 for t-56 and everythign needed
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i was just lookin on thirdgenresource and i found that they sell t-56 6-speed trans with the bellhouseing, clutch, pressureplate, flywheel, slave cyl. , master cyl. and even pedels.
now form wut i have heard and seen this is an amazing deal. am i correct? also i have a t-5 in my car so i woudln;t need the pedels or master cyl. right?? thanks
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I was thinking of buying that one, but decided I would rather have a built 700R4 for that price rather than a stock OEM 6 speed out of transam with miles on it.
Yeah its a good deal but for that price, like i said, 700R4... Built to the max...
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Most of the kits I've seen go for about 1500, so thats a decent price. You can find them cheaper than that though, I got mine for 1300. Since you already have a T5, you won't need the pedals, but you will need the clutch hydraulics. You are also going to need a tranny crossmember, and if you have an electric speedo, a signal conversion box from dakota digital. If its mechanical, I'm not sure how to set that up.
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
good price, but they (thirdgenresource) rarely have that kind of stuff in stock................call them
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Don't you need a new crossmember also?
Car: 2002 Formula Firebird
Transmission: 4l60e
If I was gonna do the swap I would just buy a complete LT1 car that has been wrecked. Ive seen lt1 cars with as low as 60k miles go for 2000 dollars here. You could probably take the tranny and still make your money back. Im sure a 60k lt1 is worth about a grand to someone.
