9 bolt axle bearings (quick qestion)
Old Nov 18, 2002 | 09:32 PM
Momar's Avatar
I put new axle bearings in when I upgraded the rear brakes. I was told by someone that I need to grease the new axle bearings or it will burn them up when I drive the car(car has not been operational yet. I had another friend that said that in school he was told that you should just lubricate them with what is supposed to be used in it(he said to check into it a little more to be safe). What do I need to do? Will it be fine with just the rear diff fluid?
Ben
Old Nov 19, 2002 | 07:33 AM
Momar's Avatar
ttt
Old Nov 19, 2002 | 11:11 AM
ede's Avatar
ede
whenever i put in new bearings, seals, or bushings i lube it with either the oil it runs in or lubriplate 105. if you don't it'll burn up before oil makes it's way to it since they aren't part of a preasurized oil system.
Old Nov 19, 2002 | 02:13 PM
Momar's Avatar
Well, I put gear oil on them when I put them in the rear, but that has been a while and it will be another while before I drive it again. If I just jack up one side of the car at a time to run fluid into each axle tube before I drive it will that make sure that they will be lubricated enough?
Ben
Old Nov 19, 2002 | 02:38 PM
ede's Avatar
ede
yeah or let it free spin by hand or run the car in gear at low speed. note with no load it'll run pretty fast.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
red90IROCls1
Aug 25, 2015 06:56 AM
Dialed_In
Aug 20, 2015 01:45 PM
