Torque converter
Old Nov 23, 2002 | 01:22 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Torque converter
What torque converter would you guys recommend for my new 357 roller combo. I was thinking of getting a hughes HUP-GM25 GM: TH350, non-lockup, 2,200 to 2,500 rpm stall speed, Street Master series, torque converter.
Old Nov 23, 2002 | 02:55 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
How about a TCI converter
Old Nov 26, 2002 | 09:18 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
you have sort of huge heads, and a sort of big intake, and a sort of big cam. you will need good gearing (3.73) and a good stall (2800+) to get the most out of your engine. TCI is ok for the price, but you should consider a "new, modern" converter.
if your on a budget and dont care about fuel economy the TCI 10" Street fighter is a good way to launch. be warned, you WILL get 3 MPG.
Old Nov 26, 2002 | 09:48 AM
MdFormula350's Avatar
ouch!! only 3 mpg
Old Nov 27, 2002 | 07:11 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I have 3.73 gears.
Old Nov 27, 2002 | 07:55 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b> was thinking of getting a hughes HUP-GM25 GM: TH350, non-lockup, 2,200 to 2,500 rpm stall speed, Street Master series, torque converter.</b>
sounds good to me, if you drive on the street. Remember, No T-brakes and no Slicks. with a carb expect 6-8 MPG on the street, especially with 3.73s and no lockup. and you PROBABLY wont want to drive it on the highway... ever.
Old Nov 27, 2002 | 07:58 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>305CID, 9.5:1, Holley 600, Stock Cam</b>
Wait I JUST got that.
You have 3.73s RIGHT NOW with a 305 and stock cam? Do you LIKE THAT?
going from 2.73 to 3.73 on my stock 305 HURT my 1/4 mile time, and sucked all my fuel away.
it will be all good, but you should remember keeping your cam's powerband within the reach of your carb/intake/heads/stalls reach.
example: 3.73 gears, Th350 2400 Stall, and a powerband Idle-4500 Rpms. very very bad. sure you get to 20 MPH real quick... but after that...
Old Nov 27, 2002 | 08:17 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I'm sorry this is for my new 357 motor:
357 CID 4 Bolt
Pro Lightning 200's with 2.08", 1.60"
Comp Extreme Energy Solid Roller XR274-12
Weiand Stealth
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
