Transmission Fluid: Which is the best?
Old Nov 24, 2002 | 05:57 AM
GrueBlock's Avatar
Hey guys, I was just wondering what trans fluid to use? a friend suggested 15W50 synthetic motor oil... because I put 80W-120 gear oil in and it feels like I have no oil in the trans at all, when I shift... Any suggestions? What seems to work the best? Thanks guys (in advance)
Old Nov 24, 2002 | 07:26 AM
ede's Avatar
ede
you might want to mention if it's manual or automatic, sounds like a manual. royal purple makes a fluid for manuals the require 30w motor oil, never used it but from talkign tio the sales rep it sounded like the way to go. i run amsoil gear oil in my wc t5.
Old Nov 24, 2002 | 02:26 PM
Pro Built Automatics's Avatar
Stick with Amsoil. From talking to the engineers that do oil testing, Amsoil and Redline come out on top (and have for years), the Royal Purple is junk (1960's technology).
Old Nov 24, 2002 | 07:10 PM
GrueBlock's Avatar
and I can get these from like Autozone? (redline, I'm pretty sure I've seen...) but whats AMS or whatever? some automatic trans fluid stuff? what weight should I use? (82 4-spd manual)
Old Nov 24, 2002 | 07:38 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Amsoil is not too common in chain type stores. Your best bet is to look in your yellow pages under Peutroleum (spelling?) and Lubricants. There are a good number of people who sell it on a smaller level or out of their homes.
Old Nov 24, 2002 | 09:04 PM
GrueBlock's Avatar
So, I believe redline is sold in chain stores, is amsoil so much better than redline that I should try to find it somewhere rather than just getting redline?
Old Nov 24, 2002 | 09:31 PM
Car: 91 RS
Engine: 350 TBI
Those 2 have a reputation for being the best on the market, but as to which is better out of the 2, I have no idea. Some Redline products are available at your local Pep Boys, but almost every town has someone who sells Amsoil. There are people who will use nothing, but Amsoil in there cars for all their lubricants, but Redline has a great reputation. It's just a matter of cost for most people. I've used Redline's Fuel System Cleaner and was very impressed, but I can't vouch for anything else of theirs. If you can't get either one of those, then Mobil 1 is your best bet behind those.
-The Gunny
Old Nov 24, 2002 | 11:14 PM
GrueBlock's Avatar
Yes, but what weight should I use? Does redline make only one weight?
Old Nov 25, 2002 | 02:29 AM
Ian Thomson's Avatar
Trans fluid
The factory uses automatic trans fluid. I prefer a 0/20 engine oil as I feel the tranny fluid just doesn't give enough protection. This trans has a bad habit of burning-up and needs all the help it can get, but heavier oil just doesn't get into the gears and bearings as it should so you have to stay with a light oil. I haven't tried any of the true synthetics because of syncro concerns...and removing it if it didn't work well. EEE
Old Nov 25, 2002 | 02:45 AM
GrueBlock's Avatar
yea, the stuff I put in there was heavy as all hell, and THICK... Whats wrong with using synthetic w/ the synchros?... thinking about using 0W20 then for my trans then..? why not synthetic? what happens to the synchros?
Old Nov 25, 2002 | 08:47 AM
Syncros
The syncros are actually like little 'gear brakes' that depend on friction to match the gearspeed to the shaft speed. The synthetic might be a little too slick for proper action. If the shifting gets stiff and 'notchy' get it out of there.The thick gear oil will blow your trans, so get it out of there! The problem with the trans is when you have trouble, it's not just bearings, it's shafts and gears, and they are EXPENSIVE!
Old Nov 25, 2002 | 09:02 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If you have a 4 speed that early the factory still used the thick stuff 80 90w. Mobil 1 it.
Old Nov 25, 2002 | 10:38 AM
GrueBlock's Avatar
Thats what I'm saying tho... I do use the thick stuff but it feels like there is nothing in there at all ;p... So I'm still thinking maybe Redline (if they are weighted, 0W20??) Can someone set me strait? .... Thank you much for your patience.
Old Nov 25, 2002 | 08:41 PM
Trans Fluid
WwHhhhoooaa. Sorry, I missed where you said it was a 4speed!!I thought (assumed ) it was a T5. The 4 speeds take 80/90W , the T5s the light stuff. I do recommend the synthetic in there as those trannys need help too. Yours is an ultra wide ratio 3.44 low gear. My sauce of choice in those is Shells' semi-synthetic 75/90...cheaper than the full synthetics and just as effective. Sorry again about the mis-direction! EEE
Old Nov 26, 2002 | 12:59 AM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Yo guys, this topic caught my eye. I'm switchin over from an auto (th350) to a T5 here right now. Everything's out i'm just waitin for all the T5 stuff. I bought a bunch of stuff from pepboys last week, one of which was trans fluid. I got the Valvoline ATF Synthetic. Any knowledge of this fluid as to wether it'll be good in the trans or if I should not go synthetic or somehting else all together?? I've always heard synthetics are better, but this is my first manual trans, so I wanna make sure I get the right stuff in there for optimal performance. Thanks
Old Nov 26, 2002 | 04:41 AM
GrueBlock's Avatar
Hey, thanks, Ian for all the help No probs on the misunderstanding... I didn't buy anything yet... so as of now, I'm getting Shell 75W90 Synthetic... err... Semi-Synthetic? sounds good... thanks a bunch!
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
