Transmition probs, shifter bounces, and moves
Old Nov 27, 2002 | 02:01 PM
86Firebirdv6's Avatar
Yeah I have a 86 Firebird, Manual Transmition, When I shift, right after I let out the cluthch, the shifter will start moving, like up an down and side to side, what is it? something is loose? any advice will help...
Old Nov 27, 2002 | 02:28 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
sounds like you have a transmission mount that is shot. I had to replace mine a few months ago. The stick would move up about 3 inches when I would let out the clutch and onto the gas.
i got a new mount from autozone for like 10 bucks. Support your tranny with a jack and remove your crossmember. You'll see the mount on there. It may fall off into your hand. At least mine did. Give it a shot.
later,
bill
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
heh he beat me to it...bad tranny mount
Old Nov 27, 2002 | 03:35 PM
Thanx for the help. also, what problems could there be until I fix it, will anything fall off? heh
Old Nov 27, 2002 | 03:38 PM
well, not that i know of. It wont be good for your driveline to move around like that. It will only take about a half an hours time to do the swap. It would possibly take its toll on the motor mounts since the engine is now torquing (sp) because the driveline isn't secured.
Old Nov 27, 2002 | 06:16 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
could also be adding extra load to u-joints, tailshaft bushing etc. I would be real gentle with it till its fixed, no dumping the clutch, power shifting, burning out...you know the fun stuff.
p.s. with the tranny twisting around like that, check your torque arm mount, make sure it hasnt been torn up too.
Old Nov 27, 2002 | 09:01 PM
all right thanx for the help guys,
Old Nov 27, 2002 | 09:09 PM
PhilM's Avatar
Car: Accepting applications...
I think I have been through about 20 tranny mounts over the years....
Old Nov 28, 2002 | 02:57 PM
what makes em brake like that?
Old Nov 28, 2002 | 07:26 PM
PhilM's Avatar
My guess is the fact that the torque arm lifts upward when you romp the loud pedal, and since it is attached to the back of the tranny, the tranny lifts upward.
that is why aftermarket torque arms like Sohn's are so cool. they link the arm directly to the chassis, and not the drivertrain.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
IROCtometal
Sep 2, 2015 02:01 PM
