1988 700r4 2.8L 3.42 governor Q
Old Dec 4, 2002 | 10:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
would a 700r4 governor in an 88 2.8L 3.42 car be lighter weights than a V-8 one ? anything to saveopff the 2.8L tranny thatd be a good thing for improving an 82-84 V-8 700r4 ?
gotta know in a couple days or less, car will be in scrap by then, i have short time window to grab parts off it..
thanks for anything
Old Dec 7, 2002 | 07:07 AM
transfixleo's Avatar
Get an '88 V-8 core and use the VB and Governor from the 2.8. Then use the TransGo Reprogramming or Shift Kit along with the High Rev Pump Kit and you will be in great shape.
Old Dec 7, 2002 | 01:49 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
good deal, so use the VB too , neato.. hmm ill have to ****** the VB and gov then off this 2.8L one, hate to waste a perfectly good 2.8L 700r4 but oh well, good for the V-8 one in the good car
the v-6 gov must have lighter weights then huh
thanks
Old Dec 7, 2002 | 03:01 PM
Pro Built Automatics's Avatar
Like Leo said, you'll need to use a 1988 & later transmission to use this valve body and plate.
Old Dec 7, 2002 | 03:04 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
so the tranny that the 2.8 parts are going onto has to be 88up also ? what about 87? i think 87 was first year of the aux VB., wasnt it ? i cant remember right no,w this is a bad time., hmm.
thanks
Old Dec 7, 2002 | 04:04 PM
A) Not all had the Aux. even in '87 and B) it is different than the '88-up, hence the answer.
Old Dec 7, 2002 | 04:33 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting.
so, but if there is an aux VB in a 700r4 then its got to be the later design right ?
thanks
Old Dec 7, 2002 | 06:37 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
anyone happen to know the weight of each weight on the 88 2.8L 700r4 governor weights vs. the 82-84 700r4 weights ? springs ?
thanks for anything
Old Dec 8, 2002 | 06:08 AM
As long as you have the Aux. VB and use the Seperator Plate that came with the '88 VB you are OK. Are you saying you HAVE an '87 Trans or you are just curious about this?
sammy52401
Nov 11, 2015 07:20 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
JSDaddy189
Sep 26, 2015 03:50 PM
6998poncho
Sep 25, 2015 02:56 PM
