fbody v6 tc work on a 700 for a 90 deg block?
Old Dec 8, 2002 | 08:44 PM
firbird's Avatar
well i am doing a quick transmission swap for temporary use because mine is going out and i have got a new transmission i got for cheep and was wondering if a TC off a 87 firbird with a v6 work, because i need a higher stall TC then a stock lo3 one. I know that the transmission is for a different deg block then the v8 one and i have heard that the bolts that hook to the flexplate are different and wanted to confirm that. And is there anything else that would make it not work if so?
Old Dec 8, 2002 | 09:54 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
A V6 torque converter is MUCH smaller than a V8 converter. I highly doubt it would even bolt up.
Old Dec 8, 2002 | 11:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
what if it does though ? woder if it would be the same effect as putting a 4 cyl th350(old vega's) converter in a V-8 th350
i heard that V-8 700r4 guys use S-10 700r4 converters all the time for cheap stall...
hmmm....
Old Dec 8, 2002 | 11:56 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i know for a fact it will not fit
Old Dec 9, 2002 | 12:12 AM
Engine: LH0 3.1L
hmmm....
Those guys are probably using 4.3 torque converters. The 4.3 is a 90* block just like the SBC and the TC is probably identical in size.
Old Dec 9, 2002 | 07:20 AM
Old Dec 9, 2002 | 02:06 PM
firbird's Avatar
thanks for all the help
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
armybyrd
Oct 24, 2015 06:59 AM
Slush92RS
Sep 2, 2015 08:56 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
