Shift lever jumps?!?!
Old Dec 12, 2002 | 01:05 PM
ZRated85355's Avatar
If i get on it in my car ( T-5 ) the shifter jumps. The whole shift lever goes back and forth pretty violently. It only does this in 3rd mostly and some times in second. Its like the tranny mount is broke or somthing. Could this be? If i get on it hard enough to really brake the tires loose in second it stops. Its only when the tires can decide to spin or not. I think the mount is broke and when the rear raps up the torque arm makes the whole tranny move because of the busted mount.
Has this happened to any of you? It drives me nuts and the big Hurst shift **** allmost broke my hand last time.
Old Dec 12, 2002 | 01:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The mount is these cars is nothing but a blob of spooge, that's supposed to handle the entire torque of the rear end trying to twist itself. It's the stupidest possible way to design something like that. They always break. They're always broken. Put an Energy Suspension one in it, you'll never have to worry about it again.
Old Dec 12, 2002 | 01:40 PM
So do you think that is the problem. What else could it be?
Old Dec 12, 2002 | 01:53 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Sounds like that's the problem to me! Also get the energy susp. like said earlier cause the stock style Stink!
Old Dec 12, 2002 | 05:30 PM
I had to get a stock one
I took mine out and sure enough it was busted. I called all over and all they had was the stock one and i needed it cause i have to drive my car
I put it in in about 20 mins and took it for a test drive. I tried everything to make the lever jump and it just wouldnt!!
Thanks for helping find the problem.
Dave
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
