T 56 Gear ratios
Old Dec 12, 2002 | 07:35 PM
CrashedMatrix's Avatar
T 56 Gear ratios
Well since i have heard some bad things about the richmond 5 and 6 speeds in my last post i guess im on to another tranny. As i was flipping through an old hot road magazine i saw a 5/16 inch adapter plate that goes on the t56 six speed. it allows you to use your stock bellhousing clutch driveshaft unlike spohns. they only thing you need is a crossmember. so im thinking about getting that and a t56. The thing is i would like to have the ones with only 1 overdrive. which years had these? how strong are they? what are there gear ratios 1-6? Or should i just get the 500ftlb torque tremec?
Old Dec 12, 2002 | 09:24 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Not sure if this is what you are looking for, but the T56s in the 4th gen F-bodies all have two overdrives but the 93 ones have less overdriven 5th and 6th gears versus the 94-up ones. The 93 model ones are only rated at 400 ft-lbs versus 450ft-lbs for the 94-up gearboxes.
The ratios for the 93 trans are:
First 2.97:1
Second 2.07:1
Third 1.43:1
Forth 1.00:1
Fifth 0.80:1
Sixth 0.62:1
Reverse 3.28:1
For the 94-up ones:
First 2.66:1
Second 1.78:1
Third 1.30:1
Fourth 1.00:1
Fifth 0.74:1
Sixth 0.50:1
Reverse 3.28:1
Keep in mind that the 98-up LS1 T56s will not work on a SBC.
Old Dec 12, 2002 | 10:20 PM
87RS402's Avatar
There is no single OD T-56, all of them have 2 OD ratios.
Old Dec 13, 2002 | 09:56 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
<b>Sixth 0.50:1
</b>
thats just sick. I mean, even with 4.11:1 rear gearing, thats still only 2..06 Final gearing. its like having a TH350 with 2.06 rear gear. its better than a 700R4 with 2.77 gearing. its insane, and i want one.
Old Dec 16, 2002 | 01:20 AM
mousemaker's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: 5 speed
It's also the same as my 3.23s and five speed (.63 overdrive), but with way more low end! It would kick some ***!
Old Dec 19, 2002 | 06:44 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Here are the specs for my T-56. Used my stock bellhousing. Infact I now use a Lakwood scattershield. Bought Spohn TA and a custom DS.
https://www.thirdgen.org/techbb2/sho...hreadid=119968
Old Dec 19, 2002 | 04:33 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
Must say it: I love my T56! Fast on acceleration, easy on gas while cruising. Best of both worlds.
Old Dec 19, 2002 | 05:03 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
shut up!
your making me cry
:rockon:
Old Dec 19, 2002 | 07:29 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
<b>Sixth 0.50:1
</b>
It is, lol......and I don't stay in first gear very long, hell most of the time I just start off in 2nd
Old Dec 19, 2002 | 09:11 PM
87RS402's Avatar
[B its insane, and i want one. [/B]
The bad part of it is my T-56 has been sitting on my dining room floor for over 6 months, I've got everything I need to put it in except the energy.
Old Dec 19, 2002 | 09:12 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
sell it to me. i got enough money to buy a blower, but i would spend it on a tranny instead
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
