700R4 Problems
Old Dec 16, 2002 | 01:00 PM
Turrisi2's Avatar
700R4 Problems
Hey i have a 91 RS with a 305 TBI and a 700R4 tranny. If im at WOT, the tranny wont shift out of 2nd gear not to mention it doesnt throw the power to the ground. My fluid hasnt been changed in a while so would changing it make that better or is it done for? It has like 128,000 miles on it.....thanks.
Old Dec 18, 2002 | 11:18 PM
Pro Built Automatics's Avatar
The capacity on the 3-4 clutch pack is just about gone with the transmission as is to handle WOT shifts. If you do not want to spend the money on a new transmission at this time, and assuming the fluid and the "3-4 clutches and 2-4 band" are in good shape, you could install the Trans-Go Performance Shift kit, Corvette servo, and the larger boost vales to solve this problem. Worst case scenario, you use these parts in the next rebuild.
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
