hydraulic clutch problem
Old Dec 29, 2002 | 09:08 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
ok,my old hydraulics went out for my clutch,so i pulled the tranny jsut to take a look around when i was replacing the master and slave. the clutch s only about a year old, well it was working fine after i fixed it and now sometimes the clutch pedal is hard as hell to push in and it wont go into gear. so waht is it? im pretty sure its either a bad pressure plate or bearing,or just ****y hydaulic stuff,but its all new.any ideas?
Old Dec 29, 2002 | 09:51 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i would bleed the clutch lines before you go nuts on replacing stuff. More than likely theres just some air in the system...
Eric
Old Dec 29, 2002 | 10:13 PM
Transmission: t-5
thats what i thought to,but air shouldnt make the clutch so hard to push in. i bled it a lil bit and when i turned the bleeder screw the fluid came out kind of slowly? im confused, damn hydraulic crap.
Old Dec 29, 2002 | 11:37 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
if all the hydraulics are new, check your pressure plate, and check your clutch fork. and i hope your throwout bearing isnt sticking
Old Dec 30, 2002 | 12:10 AM
Transmission: t-5
wuts the throwout bearing? u mean the bearing thats on the clutch fork ?
Old Dec 30, 2002 | 12:47 AM
Car: '91 Camaro RS
yup....its not likely but it could be sticking on the shaft
Old Apr 9, 2003 | 09:55 PM
Transmission: t-5
update,i ficed it,one of the pressure plate springs popped out n got between the presure palte n clutch disk , but i got a new one,so its all good now...now im building up a 383 stroker...
theshackle
Aug 31, 2015 10:47 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
rsrmoore
Aug 7, 2015 08:44 PM
