drum to disc questons
Old Jan 1, 2003 | 01:52 AM
nv the bowtie's Avatar
i was at the salvage yard tday and came across a podi disc rear for my car i was wandering what i will need off the car to be able to convert my drum to the disc.thanks.
Old Jan 1, 2003 | 10:38 AM
ede's Avatar
ede
it'd help if you said what sort of car you had and what the bone yard rear was out of. if you have the right sort of car and the rear came out of the right sort of car it might be a dorect bolt in.
Old Jan 1, 2003 | 05:02 PM
i have an 87 camaro sport coupe , the car im gettint this rear out of is between 85-90 trans am.
Old Jan 3, 2003 | 09:03 AM
lunatic_magnet's Avatar
Car: 87 camaro
Transmission: 5-speed
yes it is a direct bolt in.
when you pull the rear out of the parts car, try to save the e-brake cables as they are different from the drum ones. other than that, you shouldnt need anything else. i hear people say you dont need the proportioning valve, but i put one in when i did my swap.
if the gear ratio is different you may need a new speedo gear for your tranny.
Old Jan 4, 2003 | 12:15 AM
thanks for the information man
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
