Trans cooler lines
Old Jan 15, 2003 | 03:04 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
Trans cooler lines
Hey guys-
I just got a stall converter, so I'm installing an aftermarket trans cooler. My question is this- Do I need to plug the holes for the cooler lines in the radiator? If so, what should I use? Some bolts and teflon tape? Any advice is much appreciated
Old Jan 15, 2003 | 03:35 PM
ede's Avatar
ede
you'd need a plug made for a flare fitting, not a bolt. i'd use both coolers instead of just the aftermarket one.
Old Jan 15, 2003 | 05:12 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
not a good idea...
Then the coolant in the radiator can actually heat up the trans fluid.
Old Jan 16, 2003 | 07:20 AM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
What I've heard is if you live where it gets cold often (northern states) then use the radiator one also (this will help the trans fluid heat up in the winter.) If you live in the south (like I do) plug the one in the radiator and just use the external cooler (since we only have two seasons here in Houston.. FLAMING HOT and "nice")
Old Jan 16, 2003 | 03:29 PM
ronterry's Avatar
Car: '94 Corvette
Yeap, exactly... The radiator will aid in the heating process.
However, not using the radiator especialy in the summer your not only going the lower the trans temp, but will also lower the coolant temp.
You might be able to find some caps at Home Depot.
Ron
84z96L31vortec
Aug 20, 2017 12:16 AM
TreDeClaw
Aug 14, 2015 06:58 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
