Rear Gears for Dummies
Old Jan 25, 2003 | 03:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ok I am read end illerate [if I can even spel that is]
I am not interested in a posi, I would just like to change my stock [86 bird T5] 1 wheel peel rear gears 3.42 to a 4.10-4.11 is there a cheap swap for this??? Is there a car or a truck that I could just steal gears out of from a junk yard and swap them in???
I am not even sure what I have besides the ratio number or what I am looking too replace, so explaine it for a dummie.
Old Jan 25, 2003 | 04:20 PM
ede's Avatar
ede
i believe if you look in 4 cylinder s10s you may find the ratio you seek, take the carrier too since you may, or will, run into problems with differant series carriers. other than the s10s (and i'm not sure) i think 3:73 is as good as you'll find in a 7.5" ten bolt rear from the factory.
Old Feb 14, 2003 | 04:54 AM
2birds40's Avatar
so your saying i can take gears and the carrier out of s10s and put them in my rearend this would be great i have three s10 rears with 4.11s
Old Feb 14, 2003 | 04:56 AM
2birds40's Avatar
by the way you can find s10s with 4.11s from the factory try the sports with the 2.8s they are pretty common
Old Feb 14, 2003 | 06:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.drivetrainspecialists.com...=28&cat=GM+7.5
I would not put a S-10 posi carrier in anything. It will be the good old Eaton Gov-Lock, otherwise familiar to many as the Grenade-Lock....
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
