pivot stud that clutch fork clips on??
Old Feb 12, 2003 | 03:37 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i have my tranny out and my bell housing and evertything off trying to figure otu a tranny problem. well on my bellhousing there is this little stud that screws into it with an allen key. the clutch fork clips on it and uses it as a pivot. well i took it out and looked at it and its worn liek crazy. i wunt to replace this but the part stores don;t knwo wut i am talking about and i have no idea what this woudl be called. does any1 have a clue? has any1 bought a new one? were coudl i get it? thanks
Old Feb 12, 2003 | 03:56 PM
Scott C's Avatar
It's called a pivot ball. I just got one from www.summitracing.com
MRG-3855G - $13.95
Old Feb 12, 2003 | 04:26 PM
Car: 89 Formula
Engine: Carbed 5.7
ok so your positive this is the thing that screws into the bellhousing on the surface that the tranny bolts to? and when u slide the clutch fork in it clips around this?i just wanna be positive its the rigth thing. also it says its adjustable? is this differen't then the stock one? or are they saying you screw it in or out ans thats the adjustment? cause i don;t think u can once the tranny is in. thanks man
Old Feb 12, 2003 | 05:48 PM
Fastcamaro87's Avatar
I was looking for one of these last month and i couldnt find one that would work. Im not 100% sure about the Summit one but if it works thats the one to go with.
Formula89 was your stock one worn in the shape of a spiral? thats what mine looked like, as of now i am reusing it with no problems, but i definitely want to replace it as soon as i can.
Also does anyone know what benefits the adjustable one has? How will changing the length, etc, effect the clutch ?
thanks
Matt
Old Feb 12, 2003 | 07:07 PM
Car: 89 Formula
Engine: Carbed 5.7
i just got my new summit and i was lookin aroudn at lakewood sells an adjustable pivot ball for 16.95. it shows a picture. it looks liek it has the big peice that goes into the bellhousing and its taped in the middle and the pivot ball screws in and out of it and has a lock nut. i woudlntl if the tranny wo udl be in the way on our cars??
Old Feb 15, 2003 | 09:26 PM
laiky's Avatar
The lakewood one does NOT fit a stock bellhousing. i don't know about the summit one.
ScottC does it fit?
I bought a lakewood scattersheild, and had to run to the speed shop for the adjustable one because the stock one doesn't fit. Also when going to the scattersheild you may need to adjust it because the new bellhousing might have slightly different dimensions
Old Feb 16, 2003 | 12:36 AM
Z_Ghost's Avatar
I got a new arm and pivot ball for my B4C from the dealer last year, so here are the part #'s.
Pivot ball (GM calls it a stud) GM # 14036058
Fork arm (GM calls it a Fork ASM) GM # 14075725
Old Feb 16, 2003 | 11:27 AM
I had heard before that the lakewood one wouldnt fit, so you guys just confirmed that.
Thanks a million Zghost i was having a hell of a time trying to find the part number for the stud, Ill be giving my dealer a call tomorrow so i can get one .
thanks
Matt
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
mfp189
Sep 27, 2015 09:25 AM
