Speedo Gear Teeth for 3:42 Gears
Car: 1988 Pontiac Trans Am
I currently have the stock speedo gear which had (2:73 gears) in my (700R4)transmission now. I want to install the right speedo gear with (3:42 Gears), so my speedometer is accurate. Does anybody know how many teeth i need on the speedo gear.
I did a search and found a formula for this. The website is http://www.sallee-chevrolet.com/Chev...tallation.html But i know there is somebody with a auto that has added 3:42 gears.
Car: 1989 C4
Axle/Gears: 307
Yes but they have so many different size tires on our cars no one gear set is coorect. www.700r4.com has a calculator that can help you, they also sell the parts.
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
what size tires do you have, tell me that and i can tell ya what gears you need (part numbers and tooth count)
ok you need
15t gray drive gear p/n 8642620
and 41t yellow driven gear p/n is 25513048 for an electric speed sensor, and p/n 1362195 for a cable drive (sorry didnt know which one you have)
84 TA NV
Sep 6, 2015 08:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
