i do have posi
Old Feb 16, 2003 | 07:12 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
i do have posi
well before i asked a question if i had posi cause i layed down 2 tire marks. i didn't try any of your test but somthing alittle funner. i went to a clean cement parking lot. i did 3 burn out. i need breaks and new tires anyways. not long ones but 3 short ones and on 3 of the 3 i left two tire marks. so i am 99% positive i have posi because u guys said i would not be able to lay down 2 tire marks frequently.
Old Feb 16, 2003 | 08:01 PM
MdFormula350's Avatar
sounds like you do have posi.
if you have a 9 bolt you can test for posi this way also..
http://www.9bolt.com/
Old Feb 16, 2003 | 09:38 PM
Z28DJP1987's Avatar
Might be a Limited Slip....
Old Feb 16, 2003 | 10:40 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
limited slip is gms name for posi, you either got it or you dont, and just cause you left two marks, that dont mean ya got it, you gotta jack the car up, spin the wheels, and see it they spin the same direction, or oposite, if its the same directioon then you got posi, or look at the axle code
Old Feb 17, 2003 | 03:42 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Or ..once again...pull the inspection cover and take a look!
Old Feb 17, 2003 | 08:40 AM
Z28DJP1987's Avatar
Check the RPO codes for G-80 (Limited Slip Rear). Also, with a 305
TBI and if its a Auto the Axle's gone to be a 10-bolt 2:73 with a open diff. GM did not normally install a Limited Slip on these base models unless it was a special order (TBI???).
Old Feb 17, 2003 | 09:02 AM
ede's Avatar
ede
pull the cover and look. leaving 2 tire marks doing a burn out proves nothing. if the traction lose is equall to each wheel and tire then you will leave 2 tire marks every time. go to a drive way put one tire in the grass and try a burn out.
Old Feb 17, 2003 | 05:33 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i had a limited slip 2.72 rear in my iroc aND I LEFT 2 TIRE MARKS FOR ABOUT 75 FEET. THAT MEANS NOTHING AND BURNOUTS are just messin up the tranny. i put in a 10bolt w/ moser parts and have noticed 2 things..
1- no more inside wheel spin on tight coners under alot of power
2-no sliding from side to side when wet outside.
look at the rearend, jack it up and run the #'s under the ham.
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
