Problems With Trans Shifting
Old Mar 1, 2003 | 11:34 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I remove valvebody to install 3-4 shiftvalve because it would not go into overdrive at wot.installed valve body back up and removed governor springs because shifts was late and put a soft spring and one hard one now I shift to fast.but the big problem is it shifts ok but when you wot it and come to a stop and take off it will stay in first gear i have to put it in park and take off at normal speed to shift ok.is this signs of stuck throttle valve
Old Mar 1, 2003 | 12:57 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It could be a Throttle Valve issue, but why did you mess with the governer? If all you were chasing was the 3-4 upshift @ WOT, then the valve assembly should have fixed that. Did you mess with the TV Cable at all? Try adjusting it to specification and see how it goes.
BlackphantomZ28
Apr 24, 2016 08:14 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
hokis
Aug 9, 2015 03:57 PM
