T5 questions...
Old Mar 9, 2003 | 09:07 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
T5 questions...
Hey. I need a T5 for my 91 305 RS that I bought last Monday. I was gonna pull it and try to rebuild but when I moved the car TWICE today (due to my stupid dad) I heard the crash of death. DAMN a T5 is loud when it comes apart. Now on to the question...
Theres a guy on ebay selling a T5 from a 92 (I think) S-10 pick up. He states that its a WORLD CLASS T5 and that it should bolt to a small block with no probs. Is this true? If so, what would I have to change/modify? If not, does anyone have a good T5 for sale? Email me if you can answer the LAST question.
Thanks!
Old Mar 9, 2003 | 09:29 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Far as I know the WC T-5 came on 88-92 camaros, so if this guy is selling what he says he is, you should be OK. Unless of course S-10s have a different trans or bellhousing or something weird.
Anybody else?
Can always do a search---
Old Mar 9, 2003 | 10:35 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
S 10 4.3 bellhousings are the same but ANY other S10 motor has a different bellhousing. Buy a book and rebuild it yourself---it's pretty easy if you go slow. Besides if you plan on keeping the car it is a skill you will need (my buddy can do the whole job now in a hour and a half)lol.
Old Mar 10, 2003 | 03:05 AM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Shifter location on a S10 T5 (to my understanding) is about 10 inches forward from an F body T5 shifter. Also beware of e-bay transmissions; the last two I looked at the seller said it had a 10 spline input shaft which I don't think chevy ever used.
Old Mar 10, 2003 | 05:33 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
OK... after HOURS of searching...
Cant use the S-10 unit. Different 1st gear ratios, different shifter locations, different spline count, and the fact that the Camaro unit is tipped over at an angle.
Oh well. The hunt continues...
Old Mar 10, 2003 | 07:10 AM
Car: 1991 RS
Wow, didn't know that. Thanks for the followup post.
S-D
Old Mar 11, 2003 | 09:26 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Get the T5 video from www.hanlonmotorsports.com for $17, then using the video as a guide, take your trans apart and assess the damage, then make a decision as to fix or replace it. Replacing broken gears can get real expensive in a hurry.
Old Mar 18, 2003 | 05:57 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
I guess I will be rebuilding it...
ontogenesis
Oct 1, 2003 08:29 PM
Iroc88z28
Apr 28, 2003 11:05 AM
Kaps
May 1, 2002 10:02 PM
Biochem
Carburetors
Oct 22, 2000 05:50 PM
