Best Tremec TKO shifter
Old Mar 12, 2003 | 10:42 AM
laiky's Avatar
Ok folks, i've decided what i'm buying myself for my birthday. I will be getting a Shifter for my TKO. The question is which is the best and why. i am looking for the shortest throws, with adjustable stops I don't want something with really strong centering springs, this is not exclusively for drag racing. My old hurst from my t5 had adjustable spring tension and i found i could shift better with the softer springs. I know Hurst, B&M, pro 5.0, and steeda make shifters. what is you opinion/experience been??
Old Mar 14, 2003 | 09:02 AM
laiky's Avatar
anybody???
Old Mar 14, 2003 | 05:29 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I got the Hurst on my TKO, but the threads are stripped (bought it that way). I have my stock T-5 **** on the stripped threads and it works great. I like the throw and vertical adjustability of the Hurst. It is much shorter than the T-5 but doesn't seem (From memory) as short as the T-56 Hurst.
Old Mar 14, 2003 | 07:02 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Pro 5.0 baby!
It has what you want.
-Schultzy
Old Mar 14, 2003 | 09:21 PM
Intercepter's Avatar
I second Schultzy. I love my Pro 5.0.
Old Mar 17, 2003 | 11:00 AM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Ripper here
Old Mar 17, 2003 | 10:19 PM
laiky's Avatar
at the risk of sounding ****. the thing i guess i'm concerned with is, how stiff the centering springs are.
Old Mar 17, 2003 | 10:22 PM
Car: 1989 GTA
What is your concern? That the centering springs are too stiff? If that is it between the hurst and the pro 5.0 you would probably want the hurst.
-Schultzy
Old Mar 22, 2003 | 01:11 AM
laiky's Avatar
when i first got my hurst shifter for the t5 i set it up as it came with both centering springs on each side. i figured it was better for drag racing. i guess it is but years later i took one pring from each side and discovered i could shift up and down much smoother and faster for normal driving. I was very pleased. Thats what i'm worried about, rowing through traffic for 2 hours a day, and being able to down shift quickly and smoothly. In my opinion stiff springs are only good for very aggressive upshifting, it gets tiresome otherwise.
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
