700r4 question
Old Mar 29, 2003 | 03:12 PM
dasumax's Avatar
700r4 question
just what everybody wanted, another 700r4 question... I just picked up this 85 firebird, it's kinda been hacked up a little. the tranny doesn't work quite right, what exactly happens when the torque converter doesn't lock up? do you just loose overdrive?
thanks
Old Mar 30, 2003 | 12:25 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
that should have nothing to do with it
from what i understand (and i may as well b wrong).......the torque converter wont really affect if your car shifts into overdrive or not........what happens when the torque converter locks up is that your car SHOULD b cruising along at a constant speed and the TC will lock up and make a 1:1 ratio from the motor to the tranny, which makes you get better gas mileage and reduces heat................so i dont think its your torque converter with the problem.............
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
