Shifter lose in reverse...backup lights don't always come on
Old Apr 5, 2003 | 08:22 PM
YellowIROC305's Avatar
Car: '86 Camaro IROC-Z28
Engine: 305 V8 (LB9)
Transmission: 700-R4
My auto shifter seems to be lose when in the reverse position. The back up lights only come on if you push the shifter forward towards park. If it's back towards neutral, they go out. Any ideas?
Old Apr 6, 2003 | 10:29 AM
MustangMuncher's Avatar
Car: 89 Camaro
Engine: 355
Transmission: Coan rebuilt TH700R-4
Reverse Lights
You have contacts on your shifter that ground a wire out and make the reverse lights come on. I had the same problem with mine and after installing a B&M Shifter it worked fine. However, I dont think you will be installing a new shifter so you can take a look at it by simply pulling the console up and rotating it to the side the contacts are on the left side of the shifter. Try adjusting it or bending it so it has a little more tension against the shifter. Hope this works for you.
Old Apr 6, 2003 | 05:29 PM
thanx! i'll give it a look.
Old Apr 6, 2003 | 09:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a black switch body on the right side of the shifter assembly that contains the reverse light switch and the park/neutral safety switch. You can loosen the two screws that hold it to the shifter body and adjust its position relative to the shifter.
Old Apr 6, 2003 | 10:54 PM
Car: 89 Camaro
Engine: 355
Hey good call, same thing I said.
Jae992
Aug 27, 2015 09:07 AM
NBrehm
Aug 25, 2015 11:49 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
