Need Help quickly!~!!!
Old Apr 6, 2003 | 03:58 PM
Mike91rs's Avatar
Ok, I've looked everywhere and haven't found the answer yet. I did the 4th gen rearend swap. Everything weny fine, but whenever I hit a big bump, or what not, my tires are rubbing the lip of the wheel well. I need to know what I should do before I order my suspension stuff...i.e. shocks, springs, etc. Also if you could post pics, and what not so I can see how everyone elses looks. Because this is only happening on the passengers side. Any help will be greatly helpful and thank you all ahead of time for any ideas.
Old Apr 6, 2003 | 06:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Read the other post you asked this question in.
Old Apr 6, 2003 | 06:45 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
What tire size are you using?????
Old Apr 6, 2003 | 09:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Maybe hitting that bump just settled your suspension? I know they do this with new cars when they are just off the assembly line, and it drops the car down about an inch or more.
Old Apr 6, 2003 | 10:34 PM
Mike91rs's Avatar
P235/R60 16 is the tire size. This has been happening a lot lately, I just didn't know if anyone else was having this problem. Plus I wanted to see any pics that you all had. thanks
Old Apr 7, 2003 | 12:54 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is mine with a 4th gen rear,
These are 4th gen rims on the car, 275/40/17 all around.
Old Apr 7, 2003 | 05:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Notice that the guy who posted pics, has wheels with the correct offset. Even though he appears to be having slight gravity issues with the front of his car!!! I believe he has a miss in his engine compartment.
Anyway, that's the easiest solution to your situation. Just put a set of 4th gen wheels on it, with a pair of spacers under the fronts.
Old Apr 7, 2003 | 07:37 AM
DJP87Z28's Avatar
That 60 series tire has a tall sidewall, a lower profile tires may help.
Old Apr 7, 2003 | 06:03 PM
Mike91rs's Avatar
Thanx for the pics
Yea about the low pro tires, as soon as I get my suspension put on I'm getting low pro tires, like the rims I've got now, but know that I want 18's . Thanks again, and keep any ideas coming!
Old Apr 7, 2003 | 09:01 PM
Zepher's Avatar
Actually I have a big miss in the engine compartment.
Old Apr 7, 2003 | 09:18 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Mike91RS, Where did you get your new rearend? I have a friend with a 4th gen that want to put 3.42 gears in his car. He is considering putting in a new rearend that already has 3.42 gears. He currently has 2.72 gears. This is on a 98 TA.
Old Apr 7, 2003 | 09:36 PM
Mike91rs's Avatar
J Free
Got my rear from Speed Automotive down in Tennessee. They carry nothing but 4th gen parts. You can really find just about anything. They've got a website. www.speedautomotive.com That should take you to they're yahoo store.
Old Apr 7, 2003 | 10:20 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
How much did you pay?
Old Apr 7, 2003 | 10:23 PM
Mike91rs's Avatar
$250
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
