tranny cooler/fittings questions..
ok I should have my new tranny cool & tc today. the cooler apparently has #6AN female on it. I was going to disconnect the lines from the internal rad and hopefully find some f-f adapters from there and run solid line to the cooler. Is there such a fitting to put on the end going into the cooler #6AN Male that can be flared?
thanks
thanks
Car: 4
Engine: 6
Transmission: 5
Yes. It would be the same sort of flare series of fittings that fuel lines would use, which is SAE inverted flare. Stock trans cooler lines are 5/16"; so what I would suggest, is using a short piece of braided line with the #6 AN fittings, maybe 6" or a foot long or so; then the appropriate adapter to the stock steel line size; and either cut your stock steel lines to a suitable length and re-flare them, or make new ones from a stick of brake line.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
