Will a 700r4 out of a 4th-gen work?
Car: 00 TA, 91 Formula, 89 RS
My 700r4 on my 91 Formula crapped out on me, I may be able to get a 93 Z28 700r4 with racing clutches and B&M shift kit, will it bolt up and fit properly and work correctly? Or is it completely different?
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i believe that the 93' was the last year for the 4L60(non electronic version) if i'm not mistaken. That one you can use. 94'+ are 4L60E (electronic version). You cannot use these.
someone else like to prove/disprove what i heard?
Car: Take
Engine: Your
Transmission: Pick
You are correct. '93 was the transitional year. Trucks got the electronic version (4L60-E) and F-cars got the old version (4L60). In 1994, it was 4L60-E across the board.
As far as compatability, I think they are 100% the same. I don't remember what a 4th gen tailshaft looks like, but that would be the only difference.
Car: `86 SS / `87 SS
Also, I think the 93 f-bodies still had a mechanical gear driven VSS, but I could be wrong. Even if not, you can slip your plastic gear onto the output shaft.
Good luck w/ the swap.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
can you go the other way around and swap a mechnical speedo 700 to vss style ? IE an 83 one to VSS 92 style ?
thanks!
thanks!
