tranny is leaking really bad from torque converter area....PLEASE HELP!
Subscribe
Apr 13, 2003 | 10:55 PM
my car started shifting kinda funny yesterday so i check the fluid this morning and the dip stick was bone dry so i add some....the fluid just rushes straight out like i was just pouring it onto the ground......and also the torque converter was making a rattling noise like it was dry or something......i checked the bolts (which i could reach with the tranny still in the car) to the front pump.....they were all snug.....what could be wrong
the torque converter is an off brand.....is there anyway that it could be the problem?
please help!
Reply 0
Apr 13, 2003 | 11:04 PM
sounds like you blown a seal.............(not good) converter maybe cracked, but i doubt it
Reply 0
Apr 13, 2003 | 11:08 PM
thats what i was afraid of
what could have done this?
cuz i just got the tranny not too long ago
the tranny was having some weird shifting problems....would that have led it to do blow?
Reply 0
Apr 13, 2003 | 11:37 PM
improperly installed/ sized
or just old age
Reply 0
Apr 13, 2003 | 11:43 PM
well the tranny was just built so i guess it was improperly installed
what would cause this.......like how would i know i have it installed right?
cuz i dont have 300 dalla to have someone else install it after i get it fixed
thanks
Reply 0
Apr 14, 2003 | 06:14 AM
did you rebuild the tranny yourself?
Reply 0
Apr 14, 2003 | 11:03 PM
no
i bought off of a guy that that bought it off of a guy that builds them for a living.....yes i know confusing LOL
but anyway the car that the tranny was originally supposed to go in was a 51 merc so my theory is that it's governer and valve body are tweeked for that boat.............
Reply 0
Apr 15, 2003 | 04:24 PM
Pump mods
This is what I did to my 200-4r pump. The 700-r4 is the same type of pump, so most of the mod can be used on it. Thanks
to Bruce Toelle of www.ptsnctb.com for this excerpt from his
"Strengthening the 200-r4" on www.turbobuick.com.
"Ok, now we modify the pump return hole by drilling it to 9/64ths. From both directions.
In pump bushing bore the 690 pump bodies have a "step" at which the bushing seats against when installed. The 082, 149 bodies do not, so we mill a slot on three sides of bushing bore 1/4 inch down. After red loctiting the teflon coated bushing, press in hole with arbor press and bushing driver. Then , "peen" the bushing or "stake" the bushing into the milled flats. Flip over , and press in red loctited seal into seal bore. Assemble all pump rotor parts in , of all things, Cam shaft install lube. The red stuff. "
I also put on a 700-4r seal retainer.
Reply 0
Apr 15, 2003 | 04:36 PM
Mine did the exact same thing as yours. It ended up that a piece of the TC had broken off. I'll post a pic.....
Reply 0
Apr 15, 2003 | 04:41 PM
Reply 0
Apr 15, 2003 | 06:29 PM
LOL @ Britton. I remember that, that was nasty. I have never seen one break like that before.
Reply 0
Apr 15, 2003 | 07:09 PM
as far as noises, I had loose bellhousing bolts (I find this out while I'm pulling the trans. ) and this I believe led to the snout of the converter being half broken off. It sounded like rod knock, except that I unbolted the flexplate to the converter, and it wasn't engine.
Just now fixed a minor u-joint problem (install dose clips!) and adjusted TV on the new 700 and all is well.
Reply 0
Apr 16, 2003 | 10:11 PM
B, you should have heard it right before it crapped out. WHAP WHAP WHAP......... BANG!
I should post pics of what those hard parts looked like...... ouch.
Reply 0
Apr 16, 2003 | 10:55 PM
Quote:
Originally posted by irocbsa
oh my, thats horrid
Reply 0
Apr 16, 2003 | 11:19 PM
heh. that's exactly what happened to my aforementioned converter with loose bellhousing bolts.
Reply 0
Subscribe
