700R4 Trans mount
Old Apr 16, 2003 | 07:27 PM
caleb's Avatar
Car: 89' Iroc
700R4 Trans mount
i need to bolt the rubber mount back to the transmission, that also bolts to the crossmember, does anyone know what size the bolt it? I found that a turbo 30 uses a 7/16"-14 bolt.
but i couldnt find anything for the 700R4!
Old Apr 17, 2003 | 10:20 AM
caleb's Avatar
Car: 89' Iroc
btt
Old Apr 17, 2003 | 12:23 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
metric, but not sure what size.
Old Apr 17, 2003 | 09:10 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
if Im not mistaken I think the bolts that bolt the crossmember to the car have the same threads Id take one out and see if it will thread in and if it does Id take it to a hardware store and get one like it and as strong as you can get so it holds up to the pressure that it has to.
Old Apr 17, 2003 | 09:23 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's 10mm x 1.25mm I think. 10mm diameter for sure, and whatever the "standard" (not fine) metric thread is for a 10mm bolt.
Old Apr 17, 2003 | 11:42 PM
caleb's Avatar
Car: 89' Iroc
your right, it was the same as the one that holds the crossmember to the sub-frame.
camaro11j
Sep 19, 2018 08:49 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
Leggman1
Aug 6, 2015 04:15 AM
