Modding a 10 bolt to run 10's???
Old Apr 22, 2003 | 12:07 PM
89IROCZZ4's Avatar
I am currently running a 10 bolt from a '90 iroc in my firebird and would like to know if anyone is using a modified 10 bolt to run 10's (or faster). If so, what all have you done to the rear end to hold and how much did the parts cost? Any help would be GREATLY appreciated. I don't want to spend 2k on a 9" or 12 bolt!
Old Apr 22, 2003 | 12:16 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
That's a lot of power to be running to a 10 bolt, I'm suprised you haven't blown it sky high yet. According to the tech articles on this site about rebuilding the 10 bolt, they're only good till about 400 or so hp (this came from from Richmond Gears). You'll definitely need a real good posi unit, strong gears (like Richmonds), girdle cover, axle tubes need welded all the way around, solid spacer, forged 28 spline axles, and a few other odds and ends I'm forgeting here.
Old Apr 22, 2003 | 12:36 PM
89IROCZZ4's Avatar
Do you all even think at this point it is worth it?
Old Apr 22, 2003 | 01:31 PM
kfoley's Avatar
Car: '85 Z28
If you build it up, it might last, but it might not. If it were me I'd want the extra security of a good strong 12 bolt that way I wouldn't blow it up in the middle of the track. Of course I'm no rearend guru or anything, this is all just from what I've heard. I'm dropping in a 400 this summer pushing 430hp and 520 tq, and I'm hoping my 10 bolt will hold together with the right parts, but as long as I can't get traction (no slicks for me) I think I'll be alright.
Old Apr 22, 2003 | 08:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I'm a firm believer that the 10-bolt is indeed a good rearend, but at the claimed "500 HP", your walking a thin line. If serious horesepower is the name of the game, then perhaps you just need to seriously consider other options.
Old Apr 22, 2003 | 09:48 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I don't see why 2k for a rear would be that bad considering you must have dumped a lot of money in your car if you are planning on running 10's. Also I don’t think the 10 bolt is allowed under track rules if you are running 10’s because it is a c-clip rear.
I have heard stories from a few guys on this board that have said they have run mid 11's on a heavily modified 10 bolt.
Old Apr 22, 2003 | 10:33 PM
89IROCZZ4's Avatar
What makes you think I have spent a lot of money so far on this?
Old Apr 23, 2003 | 05:55 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
89 Iroc Z is absolutely correct, I forgot about the "no C-Clip" rule that is in place for cars that are so fast. I don't remember what speed/ET it is, but thats another thing to consider.
Old Apr 23, 2003 | 03:19 PM
PhilM's Avatar
Car: Accepting applications...
yeah man, 10.99 and quicker, aftermarket AXLES and retention device needed. good luck coming up with that stuff for a 7.5...
Old Apr 23, 2003 | 04:12 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I have read on the racing board here if you have rear disk brakes most tech inspections will pass it as an axle retention device.
Old Apr 23, 2003 | 04:18 PM
Toyota Guy's Avatar
Car: 1981 Toyota Supra
Engine: 5M-GE 2.8l DOHC I6
Transmission: 4 speed auto w/OD
9" and forget it
Old Apr 23, 2003 | 09:33 PM
Mark W. Winning's Avatar
My friend used to run a NOS'd Manza with a 7.5 rear. After market axles, spool, strange studs, brace, girdle cover, and some things I cannot remember. Its was a 10.70 car. It kept blowing ring gears. It appears that the rears flex so much that the ring and pinions become mis-aligned and fail.
As Toyota said, 9" and forget it...
Mark
Old Apr 23, 2003 | 10:56 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
An 8.5" ten bolt will live , if it's built right.
But I wouldn't count on a 7.5" to survive for long.
9" or 12 Bolt are your best bets.
-Rich-
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Dec 27, 2019 04:14 PM
Elliswon
Aug 10, 2015 12:33 PM
