Yes or No
Old Apr 22, 2003 | 09:13 PM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
Yes or No
Will a 3-speed 200 trans from a 1983 V6 firebird bolt up to a V8?
Old Apr 22, 2003 | 09:17 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
No
Old Apr 22, 2003 | 09:56 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
double no
can i ask why you would even desire to do such a thing in the first place?
Old Apr 23, 2003 | 08:11 PM
4MULA88's Avatar
just to get the car on the road.
Old Apr 24, 2003 | 12:00 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Not going to work.
Old Apr 24, 2003 | 02:18 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
bellhousing no workie.
Old Apr 24, 2003 | 05:52 AM
ede's Avatar
ede
not even to "just get the car on the road"
Old Apr 25, 2003 | 01:56 AM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I think you can buy a bellhousing converter plate, but the engine will destroy the trans before you get to enjoy it. Don't bother.
Old Apr 25, 2003 | 07:31 AM
txhotRS's Avatar
sorry pal, I'd try a junk yard for a good condition (well, for junk-yard selection) TH350 or a 700R4(especially this one BECAUSE it has automatic overdrive) you can usually get one for UNDER $ 70... I've had VERY good luck with 2 seperate junk-yard tranny's in to seperate cars.. I DID GET A cheap rebuild kit for both though... AND WOULD SERIOUSLY RECOMEND IT
Good Luck
