T/V cable problem
Old Apr 23, 2003 | 06:30 AM
guza's Avatar
Car: 1985 Berlinetta
Engine: 305 4BBL
T/V cable problem
I adjust my cable procedure below, everything works fine for about a day, if that long. Then, things go bad and teh car will take forever to shift 24-30 MPH in first. Second gear comes in hard, squeels the tires and kicks the rear sideways. Third gear is also late.
My 17 year old son drives the car. Believe it or not, he complains about 2nd gear scratch!
Does this sound like a cable stretch or maybe adjusting wrong?
1.push button
2.push black sleeve all the way towards firewall
3.floor pedal
Old Apr 23, 2003 | 02:40 PM
82Z28NAZ
Guest
Posts: n/a
instead of using the gas pedal, try rotating it out with the throttle linkage.
Another method is to hold the throttle linkage open all the way, push the button in, and push the black sleave in till it stops without moving the throttle linkage
9192camaro
16
Feb 3, 2019 12:21 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
