Help Diff plug problems
Old Apr 24, 2003 | 11:39 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I am putting a new diff in my car. Well new to me and I went to pop the plug to fill it off and it wont budge. Also the ratchet just wants to strip out the plug. Has anyone had this problem? I need help despritly.
Old Apr 25, 2003 | 07:48 AM
txhotRS's Avatar
WD-40 the hell out of the bolt on the sides where it is screwed into the cover... let it soak for an hour or two (to eat up the rust) (depending if you have lots of rust) and try it again...
even if it looks pretty clean of rust... let it soak for a while.... That should do the trick
Old Apr 25, 2003 | 08:17 AM
ede's Avatar
ede
pb blaster is abou the best penetrant you'll find, try it. a little heat will work too.
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
draco
Oct 4, 2015 09:25 PM
Bert87
Aug 23, 2015 03:50 PM
