what rear can i use?
Old May 1, 2003 | 08:27 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
hey guys im lookin into getting a posi rear for my car, and id just like to know where the best place is to get one other than a junk yard. i just dont want to end up getting a crap worn out posi and whatnot..and can i use a rear end from maybe a monte carlo or something of the sort?
Old May 1, 2003 | 09:17 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
u can use a rear from a 3rd or 4th gen f-body. u can not use a montys rear becuz there different. or go with moser, currie but i doubt ur making that kinda torque right now to snap a rear but hey never know. that or get a eaton posi for a 10bolt 7 1/2'' or 7 5/8'' rear with 26spline axels and get a set of richmond gears from jegs. or u can get an auburn posi which is cheaper then the eaton.
Old May 1, 2003 | 09:50 PM
Engine: 350 CID
im not lookin to spend over 1200 on a rear...if that helps
Old May 2, 2003 | 01:45 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
LOL ohhhhhh okay , but yea i would call junkyard to see if they have any late model camaro's or TA's and pull the rear out of them. i think most of them come with 3.42 gears already
Old Aug 3, 2003 | 03:20 PM
pat12spe's Avatar
I was thinking about going with a 3.42 also but curious as to which one I should get. I've heard auburn is a pretty sick posi, but the eatons are rebuildable. Which ones are the best ones out there. Also, are there any other reputable ones out there that are just as good? Where would be the best place to look for one? Online or in a 4th gen in a junkyard? Thanks for the help.
Old Aug 3, 2003 | 04:42 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
If you're looking for a 4th gen rearend with 3.42s you need to find a 6 speed or M6. The 3.42s came stock with them. I know I have a 35th Anniversary SS.
Old Aug 4, 2003 | 01:48 AM
Kuejo's Avatar
Car: 1988 IROC
Is 4th gen a direct swap for 3rd gen?
I thought I read somewhere that the 4th gen rear end sticks out an extra two inches on each side if you try and mount it on a third gen (although apparently very doable - the brackets and all are VERY similar!).
I went throught his whole nightmare with my 1968 Firebird, trying to find a decent rear end without spending an arm and a leg. FINALLY found out that the 2cd gen Nova's were a direct swap. Proble, with the second gen Camaro's/Firebird's was that the rear was about an inch wider on both sides.
Jonathan
Old Aug 4, 2003 | 02:28 AM
Engine: 350 CID
Re: Is 4th gen a direct swap for 3rd gen?
exactly right...ive heard its an extra 2 inches on each side also, alot of people have done it on this board.
Old Aug 4, 2003 | 09:26 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
nd if u do that u can put some nice 10 spoke 4th gen ss rims on it and make the car look nice
Old Aug 4, 2003 | 11:16 AM
Engine: 350 CID
or 2000 C5 rims..and the best part about having a 4th gen rear and 4th gen rims is that you only have to buy spacers for the front rims.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
