Blown trans???
Old May 8, 2003 | 09:15 PM
86camarodriver's Avatar
Blown trans???
The other day I was headed to school and going down the highway the trans slipped just a little twice, on the way home I was stuck in traffic then when I got out I got on the gas nice and easy and at 50mph it slipped up to 5000rpm and so I backed off and put my foot back on the gas and it did it again, droped into another gear (auto trans) and got nothing, tried second and first ang got noting but slipage, and to get it off the highway I had to hold it at 5k just to get 50mph. One guy said bad torque converter some other said the trans is blown. I can drive in first for a little bit then the RPMS jump up into the roof. Whats funny is that on the highway when I took my foot off the gas the rpms droped to normal, then jumped then droped to idle. Fluid and filter were both changed last summer, fluid is a tad dark but not to bad and there is plenty of fuild in the trans.
David
P.S. V6 car 700-R4.
Old May 8, 2003 | 09:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Probably ate the clutches... I did that too in my OEM 700-r4. I lost OD, then 3rd... 2nd on the way to shop... then 1st was slipping up to 6000 rpms and I was going about 25 mph (3.27 gears).
Might wait to see what other people say I'm no expert I'm probably wrong.
Old May 8, 2003 | 10:39 PM
91Z28-350's Avatar
rebuild time.
Old May 9, 2003 | 02:19 AM
Pro Built Automatics's Avatar
Transmission is history most likely. What condition is the fluid? Did it do this all at once?, or did it start slowly? Torque converters will not do this.
Old May 9, 2003 | 05:08 AM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
crazy...
my transmission did that exact thing today!!
once before i lost 3-4 gear and had my tranny rebuilt, this time i lost 2,3 and 4th....im not rebuilding it again. Time for new tranny.
Josh
Old May 9, 2003 | 05:12 AM
If you lost the 2-3-4 shifts all at one time, then most likely it is the governor gear (broken or stripped).
Old May 9, 2003 | 05:19 AM
Car: 1990 Iroc-Z
governor gear?
Old May 9, 2003 | 08:16 AM
It did it all at once, i hope its just one thing and not needing an entire rebuild, I going to try and get it into a guy I know at a trans shop soon. Fluid looks a little dark but nothing major, same amount in as last summer.
Ghettobird52
Jul 5, 2024 11:18 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
colton_carlson
Mar 8, 2019 12:21 PM
Hawk312
Aug 22, 2017 08:55 PM
earlpote
Aug 28, 2015 10:42 AM
