A.C.T. torque convertor
Old May 12, 2003 | 12:11 PM
camaro_1983_383's Avatar
i need to find out who to talk to to get a ACT tq convertor. i talked to user pro built automatics before, but he isnt answering my PM's anymore. i need to order one right now. is this art carr transmissions? if not, what does act stand for? any other good brands?
Old May 12, 2003 | 05:46 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Here is their website. www.actperformance.com
I bought mine through pro-built and its a damn good converter. You will not be dissapointed if you get one. Also go to pro-builts website, get the number and call and talk to Dana. He can get you the converter for $545.00
Old May 12, 2003 | 06:47 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Here, I will make it even easier for you. Dana is very busy buildings some great transmissions. Here is his number. Give him a call at 1-800-776-3288. I have always been able to reach him after 3:00 EST. I would also call and talk to someone from MidWest Converters(not sure of the number). www.raceconverters.com MidWest is pretty new but there converters are some of the bests available from what I have heard. I've got one sitting in my garage right now waiting to go into my Pro-Built 700R4 once it arrives.
Old May 12, 2003 | 10:36 PM
i just talked to someone over there at pro-built. i am not sure his name, but he is a member of this site. thanks for the help.
Old May 13, 2003 | 12:37 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
just some funny info i found the act 9.5 inch convertor is a reworked convertor from a 79 pinto. absolutly no kidding here ask the pro's who know.
Old May 13, 2003 | 11:04 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
A reworked Pinto convertor? That is pretty funny...are you playing here all week?
Who are these "Pros who know"??
Old May 13, 2003 | 03:32 PM
Pro Built Automatics's Avatar
Everybody in the torque converter business uses the back half (pump) from some existing torque converter.
(1) A.C.T., Precision Industries, Yank, use the TH125. (9.5")
(2) Art Carr, TCI, A-1, use the Pinto. (9.5")
(3) Pro Torque, uses the Mazda. (10")
This information is for the 9.5" or 10" lockups. The cover on most of these torque converters is from Sonnax, with the exception of Precision Industries (they make their own) the back half (pump) is of their choice.
Old May 13, 2003 | 03:47 PM
Engine: LS3
Transmission: 6L80E
That sheds a bit more light on it...
Apparently the ACT is a bit more than a "reworked stock Pinto" convertor.
Thanks for the input Dana...
Old May 17, 2003 | 12:47 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
if you are going to quote somebody then do it but don't add words i never said "stock"
i have a act 9.5 convertor in my car and i like it.
the first line in my post said i i just thought it was some funny info. i didn't mean anything bad at all.
Old May 17, 2003 | 01:01 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
hey dana the 700r4 and the convertor are holding up great thanks again
the names mark bought it last july formerly from aurora il
Old May 20, 2003 | 01:57 AM
actperformance's Avatar
ACT CONVERTERS
YOU CAN GET IN TOUCH WITH ME AT (818) 785 - 7574
IF YOU WANT TO ORDER A CONVERTER , YOU WOULD HAVE
TO DO SO , THROUGH DANA
I DO NOT USE A PINTO CONVERTER TO BUILD A CONVERTER.
I START WITH A TH125 CONVERTER
IF YOU ORDER A MAG SERIES , THEN YOU GET A FORGED COVER THAT I PURCHASE FROM SONNAX .
IF YOU ORDER A MAG 9.5 SERRIES THEN YOU GET A CONVERTER WITH MACHINED RING FITTED ON TO THE CONVERTER , TO FIT YOUR APPLICATION , WITH BALLONING PLATES.
IF YOU ORDER A MAG 10 , THEN YOU GET THE SAME CONVERTER AS THE MAG 9.5 SERIES , WITH OUT THE BALOONING PLATES INCORPORATED TO THE CONVERTER
ALL MY CONVERTERS ARE FURNUCE BRAISED AND HAND BRAISED/ ELECTRONICALLY BALLANCED
ALL MY RESEARCH ON CONVERTERS ARE BASED OF MY 87 BUICK GN / TWIN TURBO MAKING 950HP TO THE WHEELS WITH A LAP TOP TO READ THE DIF IN RPM OFF THE FLYWHEEL AND THE DIF .
THIS TELLS ME THE SLIPPAGE PERCENTAGE , THIS ALLOWS ME TO COME WITH DIF COMBINATIONS IN BETWEEN PUMPS AND STATORS AND LEARN IN REAL ACTION WHAT IS BEST FOR YOUR VEHICULE
THANKS
SAL
Old Jun 16, 2003 | 05:18 PM
Birdman7389's Avatar
TTT for dana and sal, some straight up guys who make kick **** products. The ones i got are still holding up perfect (even though i sold the car to a buddie )
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
