slipping fourth gear
Old May 23, 2003 | 05:05 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
hi my name is antoine and my trans is shifting funny will slip in fourth gear when you apply sum throttle only,could it be valvebody problem.or 2-4 band also going into second will still bark the tires.and not slip.
Old May 24, 2003 | 01:44 AM
Pro Built Automatics's Avatar
If the 2-3 shift is real soft or it is a long shift, then it is a 3-4 clutch problem, it is going away.
Old May 24, 2003 | 12:25 PM
antoine's Avatar
2-3 is soft and you can t even fell it when it go into fourth gear does a total rebuild have to be done or put your 3-4 clutch pack and transgo shift kits in it
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
billybob6110
Sep 23, 2015 01:30 PM
Linson
Sep 21, 2015 01:08 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
