Looking for a junkyard 12 bolt rearend, what should I get?
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I'm looking to pick up a 12 bolt rear, what cars or trucks can I look for in the junkyard that has these rear axles?
Are there any other strong rear ends that would fit? I know that there are modifications that have to be done, to get the things to "fit"
Really all I'm concerned about is an axle that is within a couple of inches of ours, I can adapt everything else to fit.
Thanks,
Mike
Thanks,
Mike
No offense, but your sig says your car runs 14.50's. Why do you need a 12-bolt? If you're planning for future performance upgrades, remember there's guys running 12's all day in LS-1's with stock rearends- and 4th gen rearends bolt right in.
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Actually you can find 12 bolts in trucks all day long in most salvage yards that I have come across.........have fun adapting though,
Tyler
Tyler
Car: 1989 Camaro RS
Yeah my car does run 14.5's with the ten bolt, and it'll probably run lower with it. But the last thing that I need to do is blow it out when I'm at the track or when I'm at school where I don't have time to work on the car. Its also important to realize that a newer 10 bolt is slightly different from the 10 bolts in our cars (yeah I could probably get one and put it in, but if I could throw in a stronger rear end why not?)
But at the same time, its true, I'll probably never have the car doing wheel stands down the highway so I could probably get away with keeping the 10 bolt but would you push it? Plus it sucks keeping a 7.5" ten bolt when no one makes parts for it. You can get the crappy littel gears for the series 2 carrier, an old posi unit or the Eaton. The eaton unit is good, but have you ever tried finding a rebuild kit for the a borgwarner or the Chevy style posi units?
I guess all that I'm saying is I don't mind spending the money for a little extra insurance, but $2grand isn't worth it when I'm capable of doing the work myself.
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
