Shifter can be shifted from 2nd to 1st WITHOUT pressing the button?!
I can just pull the shifter from 2nd to 1st WITHOUT pressing the button in and make the transmission downshift... I do NOT like this. How can I fix it?
Also, when I go from Park to Drive... it JERKS. Could these problems be related to the shifter cable (not the TV cable)?
-Thanks
-Thanks
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
This is why a lot of folks prefer the control of an aftermarket shifter - B&M Megashifter, Hurst, etc.
When I had the auto in my car I loved my megashifter. Not terribly expensive. You might want to consider. Second to First is not as bad as any gear to Reverse
HTH
-Schultzy
HTH
-Schultzy
thats weird, my shifter wont even go into first ut i can shift between Overdrive and drive without the button. it would be nice to be able to feel how my car acts in first gear, i have to use 2nd ffor good acceleration up to 50mph ans then i shift to drive or overdrive to go faster. drive and overdrive have crappy accelerationstopping at like 20 mh and taking awhile to shift. what do you think i need, a new transmission?
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
