stick to auto swap
Old Jun 4, 2003 | 03:53 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
stick to auto swap
hello all, im new around here so be easy on me. I am building a KITT conversion out of my 1982 TA V8, and would like to know what is all involved in changing my T-5 manual to a Automatic, would the shifter assembly out of a V6 setup work, like the center console shifter?, this car doesnt have a rearend, so i will be using the rearend out of my V6 Bird, My TA is a carb 305, any help is appreaciated thanks
Old Jun 4, 2003 | 04:20 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Yes, The shifter should be the same
Old Jun 4, 2003 | 04:44 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
also one other question i have is, what kind of wiring is gonna have to be added in? i know that the wires off the T5 for the reverse will be hooked upto the auto shifter, what about all the other wires that hook onto the auto shifter?
Old Jun 4, 2003 | 04:58 PM
Car: 85 Z
Engine: 383
On the clutch pedal there will be a neutral safety switch I think they are Brown and purple good size wire you will need to run them wires to the shifter. The shifter should have the same size wire don't know if the color will match but you will be able to tell what ones because of the wire size and that should be it. OOO...There will be two extra wires on the shifter that you will not need to use I think they are Black w/White stripe and Orange w/ Black stripe....Hope this helps!
Old Jun 4, 2003 | 05:14 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
oh belive me it does, im 15 yrs old, these are my first cars, and dont got alot of money, so every little tidbit of info on doing this swap helps me greatly,
will i need to get a diff speedometer since it will be changing to auto? is there any other wiring that will need to be changed?
Old Jun 4, 2003 | 05:20 PM
Car: 85 Z
Engine: 383
What tranny you going to run? TH350 or a 700R4? You can use the same speedo but you are going to have to get diffrent gears so it will read right. There should be no other wiring I just did that swap on my car and that was all I had to do.
Old Jun 4, 2003 | 05:22 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
700R4 most likely, i havent gottten a auto transmission to replace it yet, but i wanted to get an idea on what is ahead of me
Old Jun 4, 2003 | 05:24 PM
Car: 85 Z
Engine: 383
What are your rear gear ratio? You know at all?
Old Jun 4, 2003 | 06:30 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
i dont not know that, how do u find that out? sorry for asking really newb questions but, and how much would a new gear cost?
Old Jun 5, 2003 | 10:58 AM
ChellysCamaros's Avatar
Hiya.. Noticed your remark about the speedo.. I just did this swap.. went from a T5 to a th350... She runs great.. problem is.. im doing no more than 40 and she shows 60 lol.. I have a 350/th350/3.73 rear end..... any help with this could help.. thanks
chelly
Old Jun 5, 2003 | 03:33 PM
Car: 85 Z
Engine: 383
What size tires?
Old Jun 5, 2003 | 11:50 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
if u are asking me chris, im gonna be using 15's mounted to turbocast rims
Old Jun 6, 2003 | 01:15 AM
15's
Old Jun 6, 2003 | 07:28 AM
Car: 85 Z
Engine: 383
Both of you can go here http://www.tciauto.com/tech_info/speedo_gears.htm
Put your info in and it will tell you what gears you need to get the speedo to work right!
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
gta90
Sep 15, 2015 04:00 PM
Bert87
Aug 23, 2015 03:50 PM
rsrmoore
Aug 7, 2015 08:44 PM
Leggman1
Aug 6, 2015 04:15 AM
