tranny help
Old Jun 5, 2003 | 09:13 PM
pskel350's Avatar
tranny help
i think my 700r4 tranny is on the way out
i cant manually shift it into 1st or 2nd...what would cause this? the tranny also takes a long time to shift when accelerating fast. i also can feel the tranny slipping in 2nd gear alot. does this all mean i should be looking for a new tranny soon?
the tranny is stock, with around 75k miles...it just has a 2200 stall.
Old Jun 5, 2003 | 09:59 PM
MCas7's Avatar
It could be the band inside. You might want to have it checked out.
Old Jun 6, 2003 | 02:43 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
With only 75k on the trans the band going is possible, I'd also check the TV cable; make sure its working correctly, and adjusted. Make sure the fluid isn't burnt and full of metal. All that stuff floating around could hang a valve in the valve body. Also could be the seals on the 2-4 servo. Does the trans flare on 2-3 shift? If not and tv is working maybe try a can of trans x. If the car sat for a long time seals coulda hardened up. This may help extend the time till a rebuild.
Old Jun 6, 2003 | 08:20 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Adjust your TV cable and check your fluid level before doing anything extreme...
Old Jun 6, 2003 | 11:56 AM
pskel350's Avatar
the tv cable seems to work fine....downshifts the tranny when i feel it should. could it still be out of adjustment?
the tranny has all new fluid and filter. the level is right also. the trans came from a 89 camaro of a good friends. the tranny did not slip when i rode in his car about 4 months ago, when we pulled the tranny out.
what should i check next?
Old Jun 6, 2003 | 02:30 PM
FyreLance's Avatar
Yes... it does control downshifting but it also maintains line pressure (I believe that's the correct term...) and so-on.. it only takes a minute to adjust, so it can't hurt... :: shrug ::
Old Jun 6, 2003 | 03:29 PM
pskel350's Avatar
ahh, i only thought it controled downshifting i will try adjusting it and see what happens
Old Jun 6, 2003 | 06:18 PM
FyreLance's Avatar
Yes that's actually a common misconception. Post back and let us know if it helps
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
